Scapegoat At Will
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by FEELTHEWHEEL, Jan 14, 2012.
  1. FEELTHEWHEEL
    FEELTHEWHEEL Medium Load Member
    412
    163
    Oct 19, 2010
    EL Cajon C.A.
    Sometimes when starting over you need to steep back from a prior occupation that had you in charge of things everyday. The bad economy has sent many X-Drivers back to the road to put up with starting all over again. This is my case and many others. Knowing first hand that it s best to keep quiet at the start of training with a new trainer just to get it over with sooner.
    I went with CRST, but this can apply to all trucking companies. Does not mean the companies are bad to work for. Placement with a company veteran does not always give the new driver right of passage to the open road. My 20 plus years, Local and OTR I have never been late with a load other than a few times with good reason. This might be common with trainers when a student asked to stop for a short wile, and the trainer will site safety as the reason for shutting down for a whole day and blame the student for the late load rather than moving on after a short time out. This happened often to me with my trainers at CRST. Not saying I never asked to stop for a short time, but am saying lets not stop all day so the trainers can F-off and blame students four late loads. This is a Scapegoat, has this been happening to you ? :biggrin_25510:
