Schneider Cpap policy
Discussion in 'Questions From New Drivers' started by Andre Roubo, Jun 26, 2014.
  1. Andre Roubo
    Andre Roubo Bobtail Member
    7
    chicago,il
    Can anyone explain to me why some Cpap are not compatible with Schneider trucks? I just recently got a new machine and the company said that it was not compatible for use with their trucks and that I would have to use one from their loaner program. I spent months waiting for a new sleep study and and machine and would like to know why I can't use it. Any insight will be helpful.
  3. freightwipper
    freightwipper Road Train Member
    9,366
    11,439
    Mar 24, 2014
    OTR
    because they have cheap beat up Freightshakers.. that's why
  4. TruckDuo
    TruckDuo Road Train Member
    6,394
    9,373
    Oct 21, 2012
    Chicago, IL
    Are they charging you for this "loaner" ?
  5. Andre Roubo
    7
    chicago,il
    No. Just for use until I get one that's more "acceptable".
  6. handlebar
    handlebar Heavy Load Member
    Bear in mind that CPAPs run on a program prescribed by the pulmonologist or sleep medicine physician. That programming is put into the PROM inside the machine, and defines how much pressure is applied to the mask by the machine, among other parameters. Unless they'd let you have the machine set by your physician, it probably won't function correctly for your body.
    The SD card, if your machine has one, stores only compliance data, meaning how many hours you've been on it, dates & times, etc., keyed to the serial number of the machine.
    The problem with your employer may have arisen out of concerns for fuel economy, if you would use a APU to run it on a.c. Or that your machine will keep running down the vehicle's battery/batteries if indeed it runs on 12 volts DC and find you unable to start up again after your break.
    73
    Wild Murphy and Andre Roubo Thank this.
  7. TomOfTx
    TomOfTx Road Train Member
    1,190
    1,406
    Jul 13, 2013
    Friendswood, TX
    Tell us what make/model CPAP machine are you using. Are you using the AC plug or a DC cigarette lighter plug? CPAP machines do not consume a lot of power. I use a Philips Respironics System One Remstar 60 Series Auto CPAP that only uses 80 watts when using the heated hose (60 watts if using a non-heated hose). I keep the AC & DC plug with me while on the truck. The DC plug for while in the truck and the AC plug in case I need to stay at a hotel for some reason or if the DC plug failed I could plug the AC plug into the truck's APU.
    Wild Murphy Thanks this.
  8. Andre Roubo
    7
    chicago,il
    Thanks. That does make sense about the drain on the batteries.
  9. Andre Roubo
    7
    chicago,il
    The brand is DeVibliss. They never heard of it before. I use the AC plug.
  10. Puppage
    Puppage Road Train Member
    4,263
    7,370
    Aug 2, 2012
    Connecticut
    I use a Respironics and it's saved my life.
  11. TomOfTx
    1,190
    1,406
    Jul 13, 2013
    Friendswood, TX
    Never heard of them? DeVilbiss has only been around for 125 YEARS! :) Have you tried using a DC plug instead? You can buy one from most of the CPAP suppliers for about $25.
