SCR Performance low, engine will derate IN..
Discussion in 'Volvo Forum' started by AlexD13, Aug 23, 2017.
  1. AlexD13
    AlexD13 Light Load Member
    298
    85
    Jun 13, 2016
    hi all, Had this light come up two weeks ago. Went into the shop and changed dosage valve. The mechanic also questioned the pump but after changing the valve and doing a regen, the code went away. Now we we have the same issue. Does anyone know what can cause it? The mechanic believes it is Engine related. he is having trouble pulling codes.
  3. Sharky88
    Sharky88 Heavy Load Member
    715
    851
    Sep 25, 2013
    What engine? Year make model would help
  4. shogun
    shogun Road Train Member
    6,075
    72,159
    Jan 23, 2009
    Doing a regen
    On mine it was the Nox sensors after the dpf and the doc were cleaned. That's one possibility.
    KB3MMX and AlexD13 Thank this.
  5. AlexD13
    298
    85
    Jun 13, 2016
    Volvo d13 2012
  6. nasriza
    nasriza Road Train Member
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    usually nox sensor s need to be replaced, i have a collection of about 50 of them hanging up
    KB3MMX and Newto Trucking Thank this.
  7. AlexD13
    298
    85
    Jun 13, 2016
    He mentioned something about possibly a harness or electrical related to the scr
  8. nasriza
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    Both nox sensors should run around 1200 with labor and all this is usually the first thing i do now when i see this derate come up, i have not seen any kind of wiring do this you can try to replace the def filters as well shouldn't be to costly there is two on on the pump and a tiny filter in the line going to injector, most of the time i have seen this fault it has been from nox sensors also sometime like winter time when people left trucks running overnight in chicago this came from excessive idle i would force a couple of regens and it would lift the derate, nox efficiency could be anything on the engine from egr being messed up and letting to much exhaust in or egr cooler being plugged to turbo injectors could cause this as well, if you run a regen monitor how it does the regen and if all temps and everything looks good. that would be a starting point and see if that gives you anything
    shreemike, KB3MMX and AlexD13 Thank this.
  9. AlexD13
    298
    85
    Jun 13, 2016
    Thanks a lot, mechanic did a regen and it lifted the derate without anything else. Now he has to see what was causing the problem.
    KB3MMX Thanks this.
  10. AlexD13
    298
    85
    Jun 13, 2016
    Thanks a lot, mechanic did a regen and it lifted the derate without anything else. Now he has to see what was causing the problem. Also, I currently run on a standard I shift with no +,- shifter. It does not allow me to remove the speed sensor in an event of a derate. I think I am going to upgrade to a premium shifter so i can remove the speed sensor and keep running and avoid a tow
    KB3MMX Thanks this.
  11. nasriza
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    did you idle a lot before this came up on the dash.
    roshea and KB3MMX Thank this.
