new 2019 Volvo. Passes 1 min brake test with no air loss at all when engine off.
When engine idling loses air 130psi to 104psi in 4 min only on secondary side. Compressor kicked on every 3-4 min.
When’d driving it will not lose air if I’m pulling with engine under load. Will lose 1 pound every time auto transmission shifts or let up on throttle it loses steadily
Any idea?
Secondary air leak only when running
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Buckeye Don, Dec 16, 2018.
Thanks speedyk. Crazy it only had 1000 miles when it started. I’ll try to get it in to the shop soon.
If it was the air dryer or purge valve it would leak all the time wouldn’t it. -
a) with both brakes set
b) with trailer brakes set, truck brakes released
c) with truck brakes set, trailer brakes released
You want to start the timer after the air maxes out.Snailexpress and Buckeye Don Thank this. -
Hey did you figure out what that leak is I'm having the same problem with mine
Fan clutch.
Dis you ever find the problem buckeye don
