i have some questions about the pre-trip. I'm sure they're all very basic questions but, can't learn if ya don't ask.
why do you put your tractor into the lowest forward gear before taking the key out of the ignition during a secure cab procedure? why not neutral? or a higher gear, or reverse/park? what benefit does 1st gear have? is there a specific reason for this?
SecureCab- why lowest forward gear?
Discussion in 'Questions From New Drivers' started by Weeezerd, May 5, 2017.
Page 1 of 4
I don't know what a secure cab procedure is.
The only time I put the truck in gear during a pre trip was when doing an air leak test with both tractor and trailer brakes released.MachoCyclone Thanks this. -
1st gear has the most revolutions of the motor in a given distance.
hmmm thanks for bringing this to my attention @Longarm I'll check it out. I'm not sure if the pretrip study materials i have tell me to use lowest forward gear for the air leakage test.
@ExOTR ahhh thanks. i bet that's what it's about. to keep it from rolling in the event that something goes wrong... I'm guessing -
Since it's been answered I now have a question.
What's SecureCab procedure?MachoCyclone and cnsper Thank this. -
secure cab is when you enter the cab using 3 points of contact, place gear shift lever in lowest forward gear, pop air-brake control valves, remove key from ignition, exit cab using 3 points of contact and chock tire. Secure Cab is also done whenever exiting the cab of your tractor, throughout the rest of the pre-trip.
that's what I've been taught. -
MachoCyclone and Weeezerd Thank this.
Weird. I don't understand the point, but hey, if it works for the school
Schools are famous for coming up with new terminology for no good reason , just to make themselves feel more important. Entire new school departments have been created like this .... See - critical theory
AM14, MachoCyclone, Balakov100 and 4 others Thank this. -
WTF is this? Secure cab? Sounds like Mickey Mouse to me.
Anyhow, you are not asking me a stupid question, Im asking the stupid question back at cha.AM14 Thanks this.
Page 1 of 4
