Can anyone tell me if such a device exists? I'm running a step and where the axles are located there's only the rub rail. I'm searching for a device to attach on front and rear of rub rail but stays above it, to secure loads down either with chains or straps. Typically I will place my remote ratchet straps directly to the rub rail at this location. I plan on running a step with a roll tarp system so placing straps on rub rail at the wheel wells will no work. Any advice would be appreciated.
Securement device
Discussion in 'Flatbed Trucking Forum' started by burke, Jul 24, 2016.
I run a short piece of chain from the stake pocket in front of the wheel to the pocket at the rear of the wheel. I hook my strap to that chain.
TripleSix Thanks this. -
Can you have j hook rails installed to span the wheels inboard of the rail?
Or chain pop ups
In the bigger truckstops, like the Iowa 80, they sell a little triangle, about 4 inches per side, that has a hook on it, no chain. Works perfectly with the MJ method. The triangle is a perfect size for that 4 inch j hook.
