securing forklifts to a deck
Discussion in 'Flatbed Trucking Forum' started by MNdriver, Jul 30, 2012.
  1. MNdriver
    MNdriver Road Train Member
    7,985
    4,371
    Feb 24, 2012
    I am putting it here, but not sure if this is the right place.
    Was looking at a partial load today of 3 forklifts offered for a dry van.
    How the heck would you secure them in a dry van unless you have eloc's or else logistics posts. And I still don't really consider that really securing them either.
    I suppose you could block and nail the tires to prevent them from sliding. But with a flat, I'd be chaining them still.
    How would you do this in a dry van?
  3. misterG
    misterG Road Train Member
    2,884
    8,981
    Jan 21, 2009
    ask my dispatcher
    block and nail the tires in place, then lag bolt a 3x4 across the forks? never had the notion to secure a fork lift inside a can truck.
    aiwiron Thanks this.
  4. MNdriver
    7,985
    4,371
    Feb 24, 2012
    Thought about that too, but I really don't want to start punching a bunch of holes in the wood floor. Makes it not so waterproof.
    I have logistic rails in the trailer, but only on the very back third.
  5. the gambler
    the gambler Medium Load Member
    330
    245
    Feb 14, 2011
    Kentucky
    Sent you a pm
    MNdriver Thanks this.
  6. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,046
    Feb 26, 2011
    Westville, IN
    You'd probably need some d rings in the floor and some load bars to keep them apart.
    MNdriver and aiwiron Thank this.
  7. skateboardman
    skateboardman Road Train Member
    6,232
    5,706
    Jan 14, 2012
    flatbed heaven
    use blocking, but the place you load will probably secure them in for you a van. or else they will have all the blocking. i would assume theyre not big lifts
  8. -insert name-
    -insert name- ATM squishier
    1,293
    633
    Jul 12, 2012
    SOMEWHERE
    Hmmm.... Newb dry van here. One of my recent loads was some Sprinter vans, They just drove them in. 10 minutes later they banged the side of the cab telling me to go.
  9. Taildragon
    Taildragon Heavy Load Member
    723
    449
    Jun 22, 2012
    Indiana
    I have hauled forklifts back when I used to haull LTL, we use to take the forks off and set them in the nose sideways, (with the side of the forklift completely against the nose), then we nailed wedge blocks under the wheels and pulled the forks up against the nose as well. Then we would start packing freight all around them and fill out the trailer. The average forkilift with solid tires weigh usually right at 10,000 lbs, it is usually stamped on the ID tag of the forklift. So the question is, with two, would you be able to axle it with two loaded like this? If I were going to haul them I would MAKE SURE that they will not move if someone pulls out in front of you and you have to hit the binders. This WILL include nailing wedges under each wheel plus the earlier mentioned plank across the forks with lag screws, and then strapping or chains. One thing to always remember hauling ANYTHING that is on wheels, that freight is impossible to keep from moving without a lot of thought. The logistics posts and strapping are not enough to hold a forklift or anything that heavy, I know exactly how you feel about punching holes in the floor, but all it takes is one stab on the brake pedal to kill or injure you or someone else. I usually nail blocking to the floor, and then use (depending on the weight), one to three straps, with each strap hooking to the next post back, so if you have three straps, you are using three different logistic posts on each side of the trailer, to spread the load out. Even this failed me though when an elderly man pulled on to the freeway in front of me in a construction zone, I wasn't going very fast, thankfully, but I had to stomp on the brakes to keep from hitting him, and all I could hear were steel strapping breaking and iron castings tumbling around in the trailer. It took me a couple of hours restacking two hundred pound castings, and resecuring the strapping. Meanwhile the elderly man just drove away in front of me, not having a clue how close he came to disaster. You don't have the options inside of a van that you do with a flat, so you must be creative. As for the logistic strips on the wall, they are usually secured to the wall posts with pop style rivets, and as such, they are only good for securing very light freight. Sorry to give you the bad news, because like you, I believe that nailing and screwing into the wood floor just takes the life out of the floor.
  10. -insert name-
    1,293
    633
    Jul 12, 2012
    SOMEWHERE
    That's what worried me, I wasn't aloud out of the truck.
  11. MNdriver
    7,985
    4,371
    Feb 24, 2012
    taildragon,
    not really bad news, real life experience and I kind of was thinking what happened to you would be worst case or close to it and that's why I asked.
    I just can't see any good coming out of this if what you describe did happen and that's what I try to plan for, worst case.
    I like my new truck and trailer. Last thing I want is to have an added risk to put me out of business like that this early in the game.
