Securing Freight, Flatbed Style
Discussion in 'Questions To Truckers From The General Public' started by Ducks, Feb 28, 2007.
  1. Ducks
    Ducks "Token Four-Wheeler"
    3,415
    3,582
    Jan 1, 2007
    Southeastern Pennsylvania
    It seems that flatbedders haul just about anything. I've seen cargo containers, rolls of fiber optic cable, large machinery, roof trusses, lengths of steel, prefabbed storage sheds... and the list goes on to include things I don't even recognize. And everything hauled this way obviously has to be secured.
    How does the driver know the best way to tie down some of these things without damaging the load from the tension of the straps/chains/or whatever they are called? Is guidance provided at the time the equipment/freight is loaded onto the bed? Or is it something a flatbedder learns from experience...
  3. DONNALOU
    DONNALOU Light Load Member
    142
    6
    Sep 28, 2005
    Louisville,Kentucky
    Most have to take a "tie down class". As far as protecting the items from chains, binders ,ect They have protectors & other equip to put in place.
    Most of it, I would say they know how to secure the load. On rare occasion they may get specific instuctions from the shipper.
  4. Brickman
    Brickman Trucker Forum STAFF Staff Member
    12,908
    12,210
    Sep 17, 2006
    WY
    Most freight that goes on a flat has to be substantial enough to handle the tension of the straps or chains. And that can and needs to be a lot most times. Some times fragile freight will be packaged in such a way as to provide tie downs that does not damage the freight. Or the shipper will tell you that there are specific places that you can tie it down with out damaging the cargo.
    When in doubt ask the shipper. I've been flat bedding for over 4 yrs and often ask the shipper the best way to tie some thing down if I don't know. After all its their product and they've been moving it longer than I have. It shows them that you care about their stuff.
    I like the challenge of cargo securement.
    Ducks Thanks this.
  5. Ducks
    3,415
    3,582
    Jan 1, 2007
    Thanks, Donna... Brickman! I agree with you, Brickman -- I bet it is a challenge, and I imagine there are times when you can learn a lot about the cargo simply by learning how to safely secure it in transit. Makes life interesting sometimes, eh? :smt023
  6. MACK E-6
    49,799
    235,669
    Not all freight is flatbed suitable, so to speak, like bags of vermiculite. Those are too soft, big, and billowy. Not to mention you would be stopping every 3 miles or so to tighten the straps up from the product settling, more so with a spring ride truck. And after 5 or so times doing this, you've pretty much cut the bags in half. Anything that settles is really better in a van. Spring suspensions cause the freight to take more of a beating, accelerating this process.
    Which type of securement to use is about strength. For example, you wouldn't use chains to secure asphalt shingles or drywall. Straps are sufficient.
    Technically, you must have no less than 2 tiedowns holding each piece of freight, and you can't have more than 10' between them. Like for a bundle of pipe 15-20' long, you need at least 3 straps.
    Ducks Thanks this.
  7. drive55cat
    drive55cat Medium Load Member
    313
    14
    Mar 3, 2007
    Pa
    It all is fastened due to different techniques, when I started
    flats it was all bags of stuff on skids, most tied with straps, but I have learned to like steel on steel. When done correctly, you can do an 800 mile drive and with checks every two hours, find that they need no further adjusment or tightning before a safe delivery to the consignee.
    drive55cat
    Ducks Thanks this.
  8. thedrifter
    thedrifter Medium Load Member
    522
    263
    May 23, 2010
    portland or.
    alot of it is common sense. If it looks like it will move. it will. I have hualed every thing you can think of on a flat bed. a load of oranges, 90 head of lambs. yes I did it no it wasn't easy. but all of that payed the bills and got me to where I could get a load going home.
    Ducks Thanks this.
  9. jtrnr1951
    jtrnr1951 Road Train Member
    Good thread, thanks for unearthing it !!!!
    Ducks Thanks this.
  10. Allow Me.
    10,742
    12,469
    May 28, 2009
    Rancho Mirage, Ca.
    Lightweight foam blocks are the worst. You can't pull too hard on the straps and you gotta tarp it to keep from the wind beating it up. PITA ! Bundles of re-bar are sweet, about 40' long.
    Ducks Thanks this.
  11. jtrnr1951
    Don't forget livestock ................especially chickens !!!!!
    Ducks Thanks this.
