So today was securement training for me as I'm going to be a new flatbedder. When they got to the shotgun coils something seemed hinkey and I decided to dig through the FMCSR book and I'm just looking for some clarification.
Now according to the safety guy teaching the class a shotgun coil, regardless of weight, must be secured by 2 chains through the eye in an X, 2 horseshoe chains, and one over the top. Now to me this seems like overkill for something like a 10k lb coil. Now when I checked my practical cargo securement book and the FMCSR I believe it states that you can secure shotgun coils by:
A: using 2 chains crossed in an X through the eye and one over the top
B: Using 2 chains one on each side in a horseshoe and one over the top
C: Using 2 straps or chains over the top of the coil one at the rear and one at the front of the coil.
All of the above assume coil bunks with friction mats and coil weights low enough to only need 2-3 chains/straps. Info above is what I understand reading part 393.120 (d) of the FMCSR. Am I correct?
Securing shotgun coils
Discussion in 'Flatbed Trucking Forum' started by gravdigr, Jul 24, 2012.
Page 1 of 3
You secure by weight, so your going to put more chains on a 40k coil than a 10 k coil, personally on a 10k coil I would just throw a horseshoe chain on each side and hit the road, its your choice to do all of that extra work.
CAXPT Thanks this. -
Logan76 Thanks this.
Chain over the top? What? They want you to throw a chain and it may come over and take an eye or a jaw out? I find 2-4 straps over the top are just enough.
i do the crossing chains in the eye, and one over the top, then after i tarp sometimes i put another on, we have some bad tarps and that helps keep them together
usually maybe 13000 pound coils, so two chains and two straps over the top, and supposed to use our heavier chains
I do this for all shot guns. 2 horseshoe, and 4 X. 2-4 straps over. Gone across and pulled out back on ALL NC SCALES having it looked at, not a problem.
Page 1 of 3
