Separate drag link
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by MRMTRANS, May 10, 2025.
  1. MRMTRANS
    MRMTRANS Medium Load Member
    352
    386
    Apr 28, 2015
    Any opinions on drag link and tie rod end separators? I've seen them all on the internet. This drag link is seized on the pitman arm bad. I tried a combination of a pickle fork and a heavy duty 2 jaw separator and careful heat, and it still won't break. The jaws keep sliding off the pitman arm-even with a U-joint service kit c-clamp trying to keep the jaws in place.
  3. Star Rider
    Star Rider Road Train Member
    1,355
    10,959
    Sep 23, 2019
    Turn the castle nut upside down, run it down flush with the threaded part. Hit it with an air hammer.
    Heavyd and Rideandrepair Thank this.
  4. MRMTRANS
    352
    386
    Apr 28, 2015
    I tried something similar, where I got the nut flush and used a 3 lb sledge. Would an air hammer work better? I don't own one.
    Rideandrepair Thanks this.
  5. Star Rider
    1,355
    10,959
    Sep 23, 2019
    I've done it that way dozens of times. I think the vibration from the air hammer is what makes it work.
    I used that same method on kingpin lockpins with great success also.
  6. MRMTRANS
    352
    386
    Apr 28, 2015
    What size of air hammer? They cost from pretty cheap to $189 for an Igersoll Rand.
  7. Star Rider
    1,355
    10,959
    Sep 23, 2019
    I had a Snap-On PH3050A
    JB7 and Rideandrepair Thank this.
  8. 062
    062 Road Train Member
    6,158
    33,276
    Oct 20, 2013
    A long stroke ingersoll will do fine.
    I think you’d be disappointed in something like a short stroke kobalt.
    Rideandrepair and Star Rider Thank this.
  9. MRMTRANS
    352
    386
    Apr 28, 2015
    Thanks. I see that one is pricey, but certainly has the most beets per minute. This is the original tie rod: 2002 FRTL with 2.5 million miles. I'm afraid of paying so much, and then still need a specialized Tiger Tool.
    Star Rider and Rideandrepair Thank this.
  10. Goodysnap
    Goodysnap Road Train Member
    3,700
    8,972
    Jul 12, 2017
    No no.
    Shock the part with a sledge on both sides where the taper is seated. Be it the spindle or pitman arm. And the tie rod or drag link will drop free without damage to the part. Put the nut on the threads just in case you mis while swinging.
    Pickle forks just damage the boot unless you’re replacing the part already and don’t care.
    Otherwise……
    These work good too.
    https://tigertool.com/collections/all-tools/products/tie-rod-end-remover-set
  11. MRMTRANS
    352
    386
    Apr 28, 2015
    I'll try hammering more tomorrow. I did beat both sides, but maybe not enough. Otherwise, I'll try the Tiger Tool. I have their brake pin tool, and couldn't get 2 of them removed. It was a pain to get them out. So I'm not a fan of that company because they were always way more expensive than other brands.
