Series 60 12.7 injector program
Discussion in 'Ask An Owner Operator' started by istumped, Apr 19, 2022.
  1. istumped
    istumped Medium Load Member
    497
    234
    Feb 8, 2015
    Has anybody done comparisons of before and after programming injectors to 75. I believe 75 is the magic number? I could be wrong. Been told truck will run better. What are your experiences? Good or bad?
  3. Big Road Skateboard
    6,235
    34,345
    May 2, 2021
  4. DUNE-T
    DUNE-T Road Train Member
    6,952
    16,864
    May 10, 2015
    Detroit, MI
    That's what she said
    Blue jeans and Bean Jr. Thank this.
  5. Rideandrepair
    17,344
    56,270
    Aug 8, 2015
    Supposed to make a difference on the low end, more power while taking off from a start. Also can cause a rough idle. You can try it, see what you think. I had my last 12.7 set to 75, seemed to make it a little more responsive in the pedal. Made it idle a bit rough. Hard to say. I’ve heard others say a dyno test showed no improvements. I’m not sure what the effect is. Maybe makes them open a bit sooner? Equal to increasing the timing maybe? Just a guess. My current Truck, I had the highest # calibration set to 75, and increased the other 5 by the same amount. I was told years ago, to do it that way, so it will idle smooth. It does idle smooth. I’ve also read that the calibration numbers are random. I don’t think it does much. I’ll probably set mine to the correct calibration eventually. I have an occasional stumble, with white smoke. The manual says it could be calibration codes. The Ddec 1 and 2, and maybe 3? didn’t have calibration codes on the injectors from what I’ve read.
  6. diesel guy454
    diesel guy454 Medium Load Member
    393
    849
    Oct 18, 2011
    salina ks
    It doesn't do anything . Just a super trucker bs story.
    Rideandrepair Thanks this.
  7. istumped
    497
    234
    Feb 8, 2015
    Rideandrepair
    Tell me about your occasional white(blue smoke) smoke stumble? I experience the same thing here. Mechanics look at me like I'm crazy when tell them. Their are no detroit guru's around here what so ever(hour south of chucago). I can get this truck at certain rpms and it stumbles plus or minus a few rpms no problem clears up like nothing happened. This is a 98 ddec 4 with injectors all set at 75. Engine is on its 2nd ecm. Haven't fell in love with the detroit's like everyone talks. However parts are cheaper than cat.
  8. Rideandrepair
    17,344
    56,270
    Aug 8, 2015
    It’s done it since my overhaul. Much worse when filters are close to full. It still does it rarely after new filters. Don’t know the cause. It happens most often after idling for at least 15 minutes. Stop for a coffee, get going, and around 1450-1600 it stumbles. I can feather the pedal and make it keep stumbling. Can also hold it steady while traveling maybe 35 mph, in the same rpm range, and make it happen, by lightly letting off the pedal. It will do it at lower RPMs too. Once it’s revved up, it goes away. Not before missing and blowing lots of white smoke. It rarely does it. I’ve cleaned the tanks with algae biocide, changed filters. Thought I had it fixed a few times. It’s a common problem apparently. I’m thinking injector harness, since it was disturbed during the inframe. Maybe it’s the pedal itself? They usually go out totally when bad. Till I change some parts, it’s a mystery.
