series 60 14L Ticking noise/bullgear
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Roadking96, May 22, 2019.
  1. Roadking96
    Roadking96 Light Load Member
    127
    57
    Jan 7, 2016
    I got 2009 westernstar with Detroit series 60 14l DDEC VI .i had overhead adjustment done on the engine.after doing the overhead i started to hear small ticking/chattering noise.mostly you can hear in the cab.its hard to hear it outside.the noise changes as rpm’s go up and down.had my mechanic take look it he’s saying that the noise is from the bullgear. And the reason he said it started doing it after the valve adjustment is that before the valves were out of adjustment and gave enough room for the bull gear to mash in just right with other gears.after adjustment everything got tighter and now the tooth on the bullgear are bit off & not mashing together just right and causing that chattering noise. he is very good mechanic but in this scenario Is not making sense to me.can the bullgear make noise after overhead?truck runs good ,no smoke, no burning oil etc..can someone lead me right direction before i spend 4k on bullgear.
  3. terryt
    terryt Heavy Load Member
    736
    777
    Apr 27, 2009
    If it was me I would get the overhead redone by some one else. There is no way that bull gear is bad they don't fail like the 12.7's did. You didn't have a noise till the overhead it the overhead.
    Hulld, Roadking96, kemosabi49 and 4 others Thank this.
  4. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Yup re do the overhead
    Roadking96, spsauerland and AModelCat Thank this.
  5. AModelCat
    158,338
    When you do a valve set all you're doing is setting the clearances between the rocker arm and the valve stem (plus I believe jakes and injectors as well). I can't see any scenario where a valve set would affect the lash in the front gear train. I'd say what you're hearing is a valve with too much clearance.
    Roadking96 and Dino soar Thank this.
  6. thaistick
    thaistick Road Train Member
    1,416
    1,737
    Dec 7, 2014
    OTR/Thailand
    I believe you can inspect the bull gear from the cam cover? on the front of the block. But as @terryt said the 14L bullgear are practically bulletproof compared to the 12.7's
    Roadking96 Thanks this.
  7. Deere hunter
    1,935
    8,396
    Aug 5, 2017
    Shallowater Texas
    Agree!!
  8. Deere hunter
    1,935
    8,396
    Aug 5, 2017
    Shallowater Texas
    By the way let us know what you find out !
  9. Roadking96
    127
    57
    Jan 7, 2016
    Talked to westernstar dealer and they said the exact same things you guys mentioned.taking it to them tomorrow.will definitely let you guys know the result.thanks everyone!!!
    bzinger, Rideandrepair and thaistick Thank this.
  10. terryt
    736
    777
    Apr 27, 2009
    what happen
  11. Roadking96
    127
    57
    Jan 7, 2016
    I made to the dealer pretty late on Friday.so with the holidays they wouldn’t be able to look at til Tuesday.
