Series 60 computer question
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by RV transporter, Mar 13, 2018.
  1. RV transporter
    RV transporter Light Load Member
    56
    46
    Dec 23, 2017
    Kentucky
    On a 2002 freightliner century 12.7 . What would have to be done to use a 1998 12.7 computer? Would it be plug and play and if so I'd it still work with an eld ?
  3. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    No reason that I can see why it wouldn't. There both ddec4. Should be I think.
    Look at the ecm on each, should say ddec4 right on it..
  4. RV transporter
    56
    46
    Dec 23, 2017
    Kentucky
    Or would it show 1998? If so could it qualify for eld exempt ?
  5. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,139
    Mar 5, 2016
    White County, Arkansas
    It's best to buy the correct computer part for your engine. Sometimes they burn up, but replace them with the correct one. Don't try to use a older.
    The 1998 engine would be a little different in some ways than a 2001 that we had. The details escape me at the moment. But spend a dollar and put on the correct new computer to your current engine. If it is a 2002 engine, put a new 2002 computer on it.
    One thing is there is a reason pre-1999 is exempt and partly thinking the older computer before 1999 cannot or will not support ELD's
    RV transporter Thanks this.
  6. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    It will support eld.
    Any electronic engine will support eld.
  7. tnpete
    tnpete Medium Load Member
    561
    609
    Jun 25, 2013
    Tn
    It would not matter. That engine S/N stamped on the block. That is what would make it Exempt from ELD's. Not the ECM or anything else. Buddy of mine just swapped a 1999 6NZ for a 2002 engine. The Kid that owns the truck. Pulls a reefer, and changed out a 500,000 mile engine. Replaced it with a Reman 6NZ from Cat. And it came with the Electronics also.
    Same shop will be replacing a 2008 engine with a 6NZ 1998 model Reman next week. And one truck was in there last week. His is a 2000 model truck, has a 2000 model engine. And he was checked into swapping out the engine also. For a 12.7.
  8. Old Man
    Old Man Road Train Member
    4,597
    13,471
    Apr 3, 2009
    Oklahoma City, OK
    It will work but, you need to check hp setting to make sure your engine internals can handle it.
    You will have to set injector trim, speedometer, radiator fan turn on may need to be changed and there are other parameters that may need changing.
  9. Old Man
    4,597
    13,471
    Apr 3, 2009
    Oklahoma City, OK
  10. Mveal72
    Mveal72 Bobtail Member
    I have a peterbilt 379 2000 model ddec 4...as i plug the eld up to the port i have no power anybody got a clue of whats wrong?
