Series 60 grinding noise #2
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by bruce25, May 18, 2019.
  1. bruce25
    bruce25 Light Load Member
    150
    90
    Apr 16, 2014
    This is my second post trying to identify whining noise that was coming from the engine upon start up in the morning. This morning there was a loud growl noise for about 2 sec 5 miles down the road I get this grinding noise with little bit vibration. It is coming from the front of the engine it might come from fan hub or from inside the front cover not sure. It just happened I made it home luckily still morning dark outside can't check yet . I checked bull gear a week ago solid no movement could fan hub make such noise to me it sounds like a bad bearings that you would get from your rear end.
  3. Rideandrepair
    17,448
    56,613
    Aug 8, 2015
    Hopefully it’s the idler pulley bearing going bad.
  4. bruce25
    150
    90
    Apr 16, 2014
    I was right fan hub went bad took belts off no noise. Finally I was worried it was something worse hope this helps someone with similar symptoms
    Heavyd, D.Tibbitt and Rideandrepair Thank this.
