Series 60 priming pump. Need advice
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Pablo-UA, Jan 15, 2012.
  1. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    I let my truck sit from december and now I cant start it.
    Starter cranks the engine, but no fire. I used ether, but engine runs till ether lets, and stalls with no fuel.
    I understand about check valve, but seems to me for more then three weeks fuel is back to tank and no fuel in pump and I cant pump it in with starter.
    So I wanna add priming pump. What a point to add pump can you advice? before filter ore after?
  3. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    After the filter is how baby cummins isl lsc and isx IS mounted behind ecm mounting plate sounds like maybe have a bad pump of maybe bad fuel line sucking air should have picked up fuel by now
  4. Heavyd
    Heavyd Road Train Member
    7,752
    6,185
    Feb 4, 2009
    I really don't think it matters, unless the primer pump itself needs filtered fuel to protect the pump gears. I would install one somewhere it is easy to get too, thats all.
  5. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    I have only one fuel filter, so I wanna add one more like on Volvo
  6. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    If you have one filter it is a Davco and it has a check valve. That could have failed but the bowel would be empty, the cylinder head could drain even with a the check valve if there is air sucking into the system after the pump. I have an adapter that I put on the fuel pump outlet, it has a male female fitting with an adapter for an air connector. I have a wet tank air tank with two female couplings in it I fill it with fuel, and pressurise it to shop air pressure I have a hose with a ball valve I plug into the bottom of the tank, I connect the other end to the fitting I installed at the fuel pump. I worked on a lot of freightliners so I would get someone to look into the tank and watch till the air stopped coming from the return line. Get some to start it if it starts bogging down I added more fuel, holding it I knew when it was getting low, so I did not fill the system with air. I used that tank to get the early "E" Cats to start, Cummins Mercedes, just plug into the compucheck fitting and flush away.
  7. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    I wanna add primary filter to catch water and bigger dirt in fuel, after that priming pump. It would be good to install all on frame rail with easy access with hood up.
  8. lastgoodusername
    lastgoodusername Medium Load Member
    444
    215
    Dec 18, 2008
    central NC
    pressurize the delivery fuel tank with compressed air. get a plastic funnel that will cover the tank opening, insert the air hose , apply air , and have someone crank the truck, mashing the fuel to the floor. this will start your truck. johnny
  9. Pablo-UA
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    I know this way. Works with DD60, Mercedes... but ruines Volvo ECM (cooled with fuel)
    I purchased Mercedes PLD engine priming pump and I gonna install it tommorow
