Servicing steering axle hub
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dino soar, Sep 9, 2019.
  1. Dino soar
    Dino soar Road Train Member
    4,791
    26,878
    Dec 8, 2017
    I'm getting ready to put brakes and cams on the front of my truck and I'd like to service the steering axle hubs.
    I began looking through the Meritor service manual and they show a unitized hub and a conventional hub. How can I tell which I have before I take it apart?
    What oil does that Hub take?
    This is for a 1995 Freightliner fld120 with a Rockwell front axle.
  3. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    Part number should be on the hub, look by #
    Rideandrepair and Dino soar Thank this.
  4. WrenchWrenchWrench
    WrenchWrenchWrench Light Load Member
    131
    118
    Jan 3, 2016
  5. Goodysnap
    Goodysnap Road Train Member
    3,716
    9,022
    Jul 12, 2017
    Conventional bearings will be oil bath style hub cap. Unitized hub is a sealed bearing and is not serviceable and only replaceable as a unit.
  6. Dino soar
    4,791
    26,878
    Dec 8, 2017
    What weight oil should go in there?
    Rideandrepair Thanks this.
  7. stayinback
    stayinback Road Train Member
    3,911
    8,256
    Jan 24, 2014
    chicago,il
    Ol Gordon packs his bearings in bulk grease by hand the old fashioned way,before he puts it back together,then puts in whatever 80/90 75/140 whatever's on sale at the time
    I've used lucas.....no issues
  8. stayinback
    3,911
    8,256
    Jan 24, 2014
    chicago,il
    What's wrong with the cams? New bushings and seals or the whole cam too?
  9. Dino soar
    4,791
    26,878
    Dec 8, 2017
    Everything new.
    New brakes new drums new cams and bushings new slack adjusters.
    The service Chambers look good so I'll put diaphragms in them. The back has all new everything also including new brake Chambers.
    It's just exactly the truck I always wanted, but it amazes me what people mechanically let go.
    Rideandrepair, baha and speedyk Thank this.
  10. Goodysnap
    3,716
    9,022
    Jul 12, 2017
    75-90 or 140 will work fine. I usually run whatever is in the diffs to keep things simple.
  11. Collie
    Collie Guest
    New chambers in the rear? Why not put new ones up front too? Springs get weak and things rust by the time its time for new diaphram. I just replaced all of mine as well at the same time. Fronts are like 30 bucks. Heck you are putting new cams in. Those cost more. Why you putting new cams in? Those should be good for over a million miles
    Rideandrepair and stayinback Thank this.
