Setting SWR
Discussion in 'CB Radio Forum' started by DirtyD, Jun 11, 2008.
  1. DirtyD
    DirtyD Bobtail Member
    28
    Jul 17, 2007
    Huntsville, Alabama
    I have a wilson lil will antenna
    i know how to set the SWR but what do you guys use to cut the antenna?
    i can't find anything that can gut it
    thanks
  3. TheXtreme
    TheXtreme Bobtail Member
    6
    Dayton,Ohio
    I have always used a pair of bolt cutters or a pair of tin snips.
  4. smokin97
    smokin97 Bobtail Member
    37
    7
    May 23, 2008
    IL
    ^X2.
    Set it with all doors closed. If possible in a open parking lot or field with no buildings close by. Just take a little off at a time, nothing like buying a new antenna and wrecking it cause you got a little cutter happy!
  5. BillJ
    BillJ Bobtail Member
    6
    Phoenix
    On my Wilson 5000 I used a hack saw (cutting at least 1/3 way through the rod)then broke off 1/8 inch pieces with plyers till the swr's were where I wanted.
