Shake Issue
Discussion in 'Western Star Forum' started by JJMUFO, May 10, 2016.
Thread Status:
Not open for further replies.
  1. JJMUFO
    JJMUFO Bobtail Member
    6
    I have a NEW 4700 WesternStar that has a shake between 70 and 80 KM. I have replaced the tires and Rims and it has not cured the problem. Is this a Common thing with these trucks? (Detroit Rearends)?
    Please let me know if anyone else has had this issue or any ideas on how this can be fixed.
  3. damutt
    damutt Road Train Member
    1,126
    370
    May 6, 2013
    Check the driveshaft?
    JJMUFO Thanks this.
  4. Sportster2000
    Sportster2000 Road Train Member
    1,480
    886
    Jan 5, 2008
    Indiana
    Do you feel it in the steering wheel?
    JJMUFO Thanks this.
  5. JJMUFO
    6
    No, it does not appear to shake in the steering wheel.
  6. JJMUFO
    6
    The driveshaft has been checked, along with a "Shaker Test" which concluded the shake was not bad enough for the machine to find it. But when you drive the truck you can definately tell theres a shake.
  7. damutt
    1,126
    370
    May 6, 2013
    We're are you feeling the shake
  8. JJMUFO
    6
    The cab is air ride, so you feel it throughtout, very minor in the steering wheel. Some in the hood, but mostly in the floor(Feet).
  9. AModelCat
    162,390
    How is the alignment? Reason I ask is my dad had a truck that the drive axles were misaligned and it caused a vibration due to the the driveline angles being off left to right. Never really noticed odd tire wear because it spent about 50% of the time off highway.
    JJMUFO Thanks this.
  10. JJMUFO
    6
    Yes I have been told its all aligned properly, This was checked within the last few days.
  11. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Check motor mount and or trans. mounts. Just had a new trans put in my truck, mechanic said mounts were toast-I also had a bad vibration under full throttle.
    JJMUFO Thanks this.
  • Thread Status:
