Shakes left right on 50-60 mph and jumps slightly on 30-40 mph.
Discussion in 'Ask An Owner Operator' started by US Trans, Jan 27, 2020.
  1. US Trans
    US Trans Bobtail Member
    I have 2015 volvo vnl670. The problem is my truck shakes left right on 50 to 60 mph and when slow down 30 to 40 mph it jumps slightly. Does anybody know what the problem could be.
  3. Big_D409
    Big_D409 Medium Load Member
    552
    729
    Dec 1, 2012
    Robertsdale, AL 36567
    The jumping around I would assume shocks. Guessing they are past their life.
    Any odd tire wear? If yes then possible your tires are reason for bounce at a certain speed.
    The shimmy/side to side movement most likely come from worn components. First thought are tie rod ends.
    Any play amongst the components? Does it go away when front end gets greased? Any grease fittings not taking grease?
  4. Dino soar
    Dino soar Road Train Member
    4,795
    26,893
    Dec 8, 2017
    That's a good answer.
    You need to go over your whole front end.
    Kingpins, tie rods, spring pin bushings, wheel bearings, tire balance, all of it.
  5. Espressolane
    17,917
    110,626
    Have any noise when this happens?
    PE_T and Cabinover101 Thank this.
  6. Cabinover101
    Cabinover101 Heavy Load Member
    726
    1,166
    Jul 28, 2019
    Also change the shocks under your sleeper if you never have. But check everything on the front end and also make sure your brake drums and wheels are centered.
  7. Cattleman84
    Cattleman84 Road Train Member
    9,947
    70,951
    Nov 1, 2017
    The Sticks, Idaho
    Have a good alignment done... Its crazy how just a slight alignment issue can cause shakes and vibration.
    PE_T and blairandgretchen Thank this.
  8. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    Out of round tires will make that thing wobble like a Weeble, too.
    feldsforever Thanks this.
  9. danny23tx
    danny23tx Road Train Member
    1,494
    2,324
    Feb 16, 2016
    Austin,Tx
    My shakes ended up being the kingpins. Find a shop that specializes in suspension.
  10. Final Drive
    Final Drive Road Train Member
    1,573
    2,505
    Jan 21, 2015
    Op
    When did the problem begin?
    Cabinover101 Thanks this.
  11. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
    Wow. A lot of info herr
