Shifting 9spd vs regular 10spd....
Discussion in 'Questions From New Drivers' started by jakescia, Sep 20, 2009.
  1. jakescia
    jakescia Bobtail Member
    32
    Aug 4, 2008
    Oskaloosa, Iowa
    I usually shift a 13spd.........and have no problems. We also have a 10spd that I drive very, very little......just enough to know I really, really don't like that 5-to-6.........so I'm really glad that engine is 500hp.
    However, we just bot a 9spd........that was advertised as a 10spd.......so I am a little concerned that whomever was driving it most of the time thought it was a 10spd.
    Like a dumb butt, I did not check the Eaton shift tag above the door before I drove it home.......
    (I would have bot the tractor anyway-------9 or 10-----so I just did not check the tranny very closely.)
    That tag says the shift pattern is left front = R left rear = low. then to right, front is 1, with 2 to the rear, then 3 to right at front, and 4 straight back...............flip the lever, 1 becomes 5, 2 = 6, 3 = 7, 4 = 8.
    HOWEVER..........when I was bringing it home, I thought it was a regular ten spd, and I downshifted from what I thought was 7 into what I thought was 6.........ie into the low hole with the lever flipped up. Gears engaged, and it seemed that it was "6", although things felt a little "scratchy". Fortunately, I had no load, and the shift was smooth and not forced.
    What do I have, what damage has probably been done, and what could happen in the future?
    We will check the tranny Monday AM and get a model number.....but a replaced tranny is totally illogical..................but I thought maybe you fellows could provide some insight anyway.
    Thanks for the help.
  3. Winchester Magnum
    Winchester Magnum Road Train Member
    1,492
    1,647
    Jan 4, 2009
    Alaska highway
    I think you answered your own question. If it's a true 9 sp, yeah, don't go into granny high. It can be done, as you experienced but I would not put in that hole again (in high)
  4. Freebird135
    Freebird135 Road Train Member
    1,527
    906
    May 7, 2009
    In the air conditioning
    i know i hopped in an 8 sp that i thought was a 10 sp and i went from 4th to low thinking i was going from 5th to 6th
    needless to say, it didnt go into gear and i quickly figured out why
