Shifting a 15 speed?
Discussion in 'Questions From New Drivers' started by risingfighter, Sep 25, 2007.
  1. risingfighter
    risingfighter Bobtail Member
    albuquerque, nm
    I was wondering if anybody had a shift sequence for a 15 speed, because the pattern was worn off of the truck I had to pick up today.
  3. broncrider
    broncrider Road Train Member
    get with brickman...he has recent experiance with a reversed 15...so it should be very easy to explain
  4. Brickman
    Brickman Trucker Forum STAFF Staff Member
    12,907
    12,209
    Sep 17, 2006
    WY
    What year??????
    Some time in the late 80s they changed it so if its later than that it should shift like a 10 spd. Most of the time you can ignore the bottom 5 as that is deep reduction used mainly for off road or where you need really slow gearing.
    If its an old trans pattern it'll be like this...........
    R 2 5
    1 3 4
  5. risingfighter
    albuquerque, nm
    Thanks alot i'm not sure what year it is, i'll find out tomarrow when I drive it. Really apprciate it guys.
  6. Brickman
    12,907
    12,209
    Sep 17, 2006
    WY
    If it doesn't want to shift with the reverse 4 and 5 try shifting it like a regular ten spd and see if that works.
  7. Powder Joints
    7,560
    7,527
    Sep 25, 2007
    Rosamond, SoCal
    Range select front lever down low up is high
    R 2 4
    1 3 5
    Upper Gears split with side lever
    R 8/9 12/13
    6/7 10/11 14/15
  8. Brickman
    12,907
    12,209
    Sep 17, 2006
    WY
    Thats unlike any 15 i've driven.
    All the ones I've driven with the range lever in the down position the side bar will shift you from low range to deep reduction.
  9. uncle bill
    uncle bill Bobtail Member
    40
    May 1, 2007
    I agree with Brickman. Any 15 i drove or saw was a 10 with deep reduction. Had to drive one today with the 4/5 reversed. BTW, I think the reversed pattern is called a RTX not a RTO. They are both overdrive trannies.
  10. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    You have it backwards, RTX shift patterns are the same as RT. RTO patterns have the top gear position in the upper right corner.
    IIRC, Eaton never really gave the 15 speed an "RTX" name, but gave the buyer an option of either shift patter, both called RTO. I don't think the reverse pattern is available anymore, except maybe as a special order, the straight RT/RTX patters are far more popular.
  11. Young-Gun-101
    Young-Gun-101 Light Load Member
    102
    10
    Feb 18, 2007
    Iowa
    we still have a freightliner with a 15 in it and we shift ours just like powder joints explained
