So the first manual I drove on a regular basis was a 18 speed hauling gravel trains with almost 1 mill on the trans. I just started with a new company hauling baffle-less tanker in a 13 with about half a mill on the trans. Both these trucks had their learning curves but I feel I picked em up pretty quick and I became really comfortable with the trans in both and could shift quickly and not grind gears. Today my truck broke down and they put me in a few veteran guys trucks with less than 200k on the trans and jeez what a world of difference. I mean i've heard of 'tight' transmissions but I hold the shifter at the face of the gear but instead of a gradual slowing click till the gear falls in you kind feel it slow down then it zips right past the hole, but if I hold it any harder im just grinding it. Im still really green but the tolerance on a newer trans is otherworldly, I can get the job done but I honestly like driving a truck thats worn in rather than these newer ones. Couldnt imagine a brand new one. Im posting a link just to kinda show where im at. This was me in the train at around 2 months, I dont have anymore recent videos. https://youtube.com/shorts/Ov9n4lNApPg?si=uY2OoKWUiaL4kJfZ
Shifting a new trans
Discussion in 'Questions From New Drivers' started by cbones98, Dec 26, 2023.
I had my transmission rebuild last year, my buddy put plenty of new gears along the way. Since the rebuild, I have trouble catching a few gears. The tolerance are to tight. So I feel you. Just be patient and try using the clutch a little more. At least using the clutch slightly has help me.
cbones98, Bud A., Oxbow and 1 other person Thank this. -
Good transmissions are like a fine wine; they just get better with age, until eventually they fall apart.
During college I moved MT units for Ryder where there was a mix of IH cabovers and conventionals.
Returning one to a remote location after maintenance and climbing into the 'loaner'; an old cabover was an experience in the extreams of shifters.
The remote linkage on the cabover felt like the stick was floating in a bucket of grease compared to the 'normal' stick in the conventional. -
Id be interested in driving a brand new trans to see if maybe its just the way these other guys broke theirs in. I try to have a pretty light hand and not just slam it in while a few other guys dont care much. One of the guys I work with said if you have the overhead re-tuned every 100k or so it helps tremendously and if done right it will almost suck you into gear. I know that that hasnt been done on any of our trucks.
Not seeing the corelation between engine valve lash and shifting. Sounds like a placebo thing to me.
High Stepper, ‘Olhand and Diesel Dave Thank this. -
Could be. Im pretty green so I couldnt say. Just something one of the senior guys brought up.
It only works if you don't have feeler gauges to set it. If it grinds a little bit shifting after the overhead, just tighten the lash a little more.77fib77 Thanks this.
“Not could be”, not even close. Erase that from your memory. That so-called “Senior” has absolutely Zero clue what he said.wis bang, AModelCat and High Stepper Thank this.
Not entirely untrue. A finely tuned engine and good shifting is like a musical instrument. Valve lash outta whack can make a engine not return to idle as fast as it should making a gear change sticky. Anyone who has operated an older mechanical and especially a normal aspirated mechanical can tell when an overhead is due by the time it takes for rpms to wind back down between shifts.
