Shifting automatics for downhill
Discussion in 'Questions From New Drivers' started by Buckeye 'bedder, Jan 13, 2011.
  1. Buckeye 'bedder
    Buckeye 'bedder Road Train Member
    1,043
    440
    Sep 26, 2010
    Nowhere
    From reading posts, I get the impression that you can manually downshift an automatic prior to starting a downgrade? The drivers who use auto, are you comfortable on relying on the computer getting you in the right gear before you start downhill?
  3. fairshake
    fairshake Road Train Member
    1,079
    1,272
    Oct 4, 2010
    Chickenville, BFE
    You can put the transmission into manual mode and downshift yourself on nearly all of them, then when you are at the bottom of the grade just click it back into auto while moving.
  4. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    There is a display that tells you what gear it is in. It is no different than you shifting, it is all preparation. Being at the right speed before hand. I drove some of the very first ones out there on road tests and after taking a course on them. They are very impressive, I like the three pedal units a lot more than the two pedal.
  5. Sequoia
    Sequoia Road Train Member
    2,692
    1,794
    Dec 4, 2010
    Tampa Bay, FL
    I never had a problem with it. I ride the jake brake down the hill if I need to. No need to mess with gears.
    Gears Thanks this.
  6. chompi
    chompi Road Train Member
    5,653
    3,485
    Jun 21, 2008
    Deland, FL
    That is one of the main reasons I hate the autoshift trucks! Scares the hell out of me in the mountains! I know that they are pretty reliable I just hate stuff I have no control over.
  7. BWSADE
    BWSADE Bobtail Member
    26
    19
    Oct 23, 2010
    Neodesha, Kansas
    Control is only a feel good word for people. No one ever has complete control over anything at any time. Example, you are driving down the road and a tie rod breaks, someone rear ends you, steer tire blows, drop a driveline on a 9% downgrade auto or manual. In all these situation your control is beyond your control. Control is 100%, these things can happen at any time, so do you really have CONTROL. Yes I always see the glass half empty I know.
  8. Buckeye 'bedder
    1,043
    440
    Sep 26, 2010
    Nowhere
    Huh? :smt017 :dontknow:
  9. striker
    striker Road Train Member
    6,023
    6,436
    Aug 8, 2009
    Denver, Co
    Before I start down Vail, Eisenhower, Genesse, Floyd, etc., etc., I put mine in manual mode (the sticker even tells you to do that) and slow to the speed I want to safely drop in based on the wieght, kick my jake on high, and let her go. Probably 50% of the time I'm in too low of a gear and have to upshift.
    Buckeye 'bedder and Gears Thank this.
  10. Ranger_309
    Ranger_309 Medium Load Member
    450
    753
    Sep 26, 2010
    Better then having to downshift on a grade, manual or auto-S###.
  11. Ranger_309
    450
    753
    Sep 26, 2010
    It depends. You got ice, rain or snow, you take it slow. Just an old trucker's advice.
