shifting ranges for trucks
Discussion in 'Questions From New Drivers' started by BigpopperRunner, Jan 14, 2020.
  1. BigpopperRunner
    BigpopperRunner Light Load Member
    198
    103
    Jan 10, 2019
    Hey guys,
    Was just wondering what are the shifting ranges for a 10 and 13 speed for a volvo and peter bilt? I tested in a 10 speed freightliner and up shifting was 10-12 RPM for low gears and 14-15 for higher gears. Down shifting was clutch out of gear and rev to 10-11 RPM and clutch it in gear. I watched a few videos and it seems the volvo's are a lot higher with the RPM around 15 RPM for upshifting and I am assuming peter bilt's run the same between 10-14 RPM? Never drove a 13 speed before.
    Thanks!
  3. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    Some of it isnt so much the transmission. Some of it is the engine itself. Caterpillars are a slower turning engine.
    MACK E-6 Thanks this.
  4. MACK E-6
    49,154
    229,092
    Detroit 60’s don’t tolerate lugging at all, where a CAT would take shifting a lower speeds better.
    lovesthedrive Thanks this.
  5. Brandt
    Brandt Road Train Member
    4,522
    6,204
    Sep 17, 2012
    I would say shift low range 1,000 RPMs because you don't have to match the gears and you don't need all that power to get rolling. Then when you go to high range shift at 1,600 RPMs. The reason you shift at 1,600 RPMs is because most transmission have a 400 RPM step between grease. So it will go into the next gear at 1,200 RPMs that also right at the most pulling power for most engines.
  6. Long FLD
    Long FLD Road Train Member
    12,002
    49,441
    Mar 4, 2015
    It depends on the engine. If it’s a newer Volvo or Paccar engine then lower rpm’s will be your friend. I run my Paccar 1000-1400, figuring in a 200 rpm drop with the split.
  7. feldsforever
    feldsforever Road Train Member
    1,453
    1,440
    Nov 22, 2019
    This Cascadia to me is difficult. Out side of school. Its the only manual tt I have driven.
    I notice its all about rpms and momentum. The speed dont mean squat. For example. When really heavy. Or when climbing a hill I have to shift early. When I down shift. I have to be going slower than the gear I want. And when I'm empty it shifts it self.
    The rpms come into affect on flat ground when carrying less than 20k. Only time I don't use the clutch. Its a 13 speed. Hope it helps ya
