Shifting
Discussion in 'Trucks [ Eighteen Wheelers ]' started by notarps4me, Mar 11, 2007.
Drivers do you
  1. *
    float?
    65 vote(s)
    43.6%
  2. *
    double clutch?
    16 vote(s)
    10.7%
  3. *
    or both?
    65 vote(s)
    43.6%
  4. *
    have an auto tranny?
    6 vote(s)
    4.0%
  1. notarps4me
    notarps4me Road Train Member
    10,311
    5,253
    Jan 1, 2007
    NASA HQ
    Drivers do you float or double clutch? Me I floated most of the time. Sometimes I double clutched.
  3. pjw044
    pjw044 Heavy Load Member
  4. Burky
    Burky Road Train Member
    It's situational. Heavily loaded or starting to pull a grade at low speed, I'll usually opt for the clutch between gears. Rest of the time, I float. It's a decision you make each time you shift, and your experience guarantees that it will be the right one for that particular moment.
    And I still don't do online polls....
  5. Cerberus101
    Cerberus101 Heavy Load Member
    986
    37
    Oct 25, 2006
    Georgia
    i find myself doing both. usually just depends on the situation............
  6. NyteWulf
    NyteWulf Bobtail Member
    42
    4
    Feb 23, 2007
    Blacksburg, Va.
    I've heard that alot of drivers float, but what is it exactly?
  7. elharrison
    elharrison "Iam on my way"
    650
    33
    Feb 8, 2007
    WV
    i think its shifting with out the clutch, i never herd it called floating but i think thats what they are refering to
  8. wallbanger
    wallbanger "Enemy of showers everywhere"
    Yep, it is shifting without using the clutch.
    If I am feeling lazy I will float, but like Burky said, if you are heavy, then it is best to double clutch.
  9. jorlee
    jorlee Light Load Member
    197
    83
    Feb 17, 2007
    ND
    I float. That was the way I was taught. I double clutched to get my CDL, but still fail to see why it's necessary.
    I can see it would help for upshifting, with a heavy load, allowing a quicker shift, but other wise it seems pointless. Clutching or not in most trucks the RPM still has to be matched.
  10. joettanne
    joettanne Bobtail Member
    15
    Ontario, Canada
    Sometimes I double clutch, sometimes I don't. It depends on the situation.
  11. NyteWulf
    42
    4
    Feb 23, 2007
    Blacksburg, Va.
    So floating wouldn't mess up the clutch and transmission?
