Shifting
Discussion in 'Questions From New Drivers' started by zoekatya, Feb 23, 2014.
  1. zoekatya
    zoekatya Medium Load Member
    397
    99
    Mar 15, 2013
    Do you have to double clutch or can you just shift as you would on a pickup truck?
  3. BrenYoda883
    BrenYoda883 Road Train Member
    1,248
    1,422
    Sep 18, 2013
    You either need to double clutch or float the gears...
    You will be able to get by with poor clutching and shifting.. but you are damaging the clutch, gears and transmision...
  4. EZX1100
    EZX1100 Road Train Member
    4,017
    5,711
    Aug 18, 2012
    it may depend on the truck, i have driven my truck over 500k, same clutch, but between 6th and 7th, i have to lightly touch the clutch to properly float
    i have never double clutched my truck
  5. rocknroll81
    rocknroll81 Road Train Member
    1,332
    930
    Sep 29, 2010
    West Allis Wi.
    You have to double clutch, they are not a synchromesh tranny for the most part, I heard that Volvo's or at least the early one's had a full synchromesh tranny like a pick up, never drove one as I have severe allergies to Volvo's. After awhile you can get good enough to shift without double clutching by not using the clutch at all.....
  6. o/otony
    o/otony Light Load Member
    190
    49
    Dec 25, 2012
    in my opinion is easier to float than to clutch, on up or down shifts.
  7. Wooly Rhino
    Wooly Rhino Road Train Member
    3,367
    5,648
    Jul 6, 2008
    Liberty, Missouri
    For the past three weeks, all I have done is push the yellow button in and then pulled it down one space to the D. For backing up you have to put it up to the R. Remember to put your left foot on the brake when you are moving from N to either R or D. And to put it back in N when you pull the air knobs.
  8. gpsman
    gpsman Road Train Member
    1,581
    1,211
    Dec 10, 2013
    45212/59759
    No, and no... unless you're not in the habit of flooring the pickup's clutch. It doesn't really matter; if the gears are in-sync, the gears are in-sync. Flooring a truck clutch engages the clutch brake and throws it all out of sync.
    road_runner Thanks this.
  9. Offender
    Offender Light Load Member
    99
    138
    Oct 25, 2013
    2003 Columbia HWY
    Up: I use light clutch pressure, so light that I'm probably just floating, on all low gears. I defiantly double clutch high gears.
    Down: I always double clutch. I can't float down as fast as I can double clutching.
    2003 Freightliner Colombia, Detroit 60, Eaton 10 speed
  10. 8thnote
    8thnote Road Train Member
    1,980
    3,687
    Aug 12, 2013
    Chattanooga, TN
    I drive a '13 Volvo with a D13 engine and an Eaton 10 speed. It's definatly not a synchromesh.
    rocknroll81 and BobcatVolvo Thank this.
  11. Ridgeline
    22,368
    116,046
    I had a 13 speed yesterday that I swear was a synchro tranny, it was so easy to drive that I thought it was a car.
