Short Haul/16 hour rule question
Discussion in 'Experienced Truckers' Advice' started by HotH2o, Jun 13, 2013.
  1. HotH2o
    HotH2o Road Train Member
    4,098
    4,865
    Sep 23, 2012
    I've recently been doing local driving. I return to the same terminal at the end of each day. My question regarding the 16 hour rule is do I get one a week or one with every reset? For example if I use my 16 hour day on Friday and get the weekend off can I use a 16 on Monday or do I have to wait until the 7th day?
  3. primedirective
    primedirective Bobtail Member
    May 23, 2010
    Atlanta, GA
    Yes you can! Until the new HOS rules go into effect on July 1. After July 1, only one time during a 70.
    HotH2o Thanks this.
  4. Wolfyinc
    Wolfyinc Road Train Member
    2,888
    966
    Apr 21, 2013
    Salem, or
    dont forget the new stupid break rule too, 30 min break after 8 hours or before
  5. HotH2o
    4,098
    4,865
    Sep 23, 2012
    Does that have to be logged as "off duty"?
  6. Ghost Ryder
    Ghost Ryder Road Train Member
    1,647
    1,182
    Jan 3, 2013
    Your Mailbox
    Yes. Chances are you don't have a sleeper to log line 2 with.
    HotH2o Thanks this.
  7. Sublime
    Sublime Road Train Member
    1,529
    1,896
    Jan 18, 2013
    Twin Cities, MN
    There is NO change in the 16 Hr exemption. It can be used once a week unless a driver gets a reset, then it can be used again.
    http://www.fmcsa.dot.gov/rules-regulations/administration/fmcsr/fmcsrruletext.aspx?reg=395.1
    o) Property-carrying driver. A property-carrying driver is exempt from the requirements of § 395.3(a)(2) if:
    (1) The driver has returned to the driver's normal work reporting location and the carrier released the driver from duty at that location for the previous five duty tours the driver has worked;
    (2) The driver has returned to the normal work reporting location and the carrier releases the driver from duty within 16 hours after coming on duty following 10 consecutive hours off duty; and
    (3) The driver has not taken this exemption within the previous 6 consecutive days, except when the driver has begun a new 7- or 8-consecutive day period with the beginning of any off-duty period of 34 or more consecutive hours as allowed by § 395.3(c).
    HotH2o Thanks this.
  8. Ghost Ryder
    1,647
    1,182
    Jan 3, 2013
    Your Mailbox
    Returning to the same terminal every day doesn't mean it's a local job. I'm willing to bet you have a line haul run.
    *sorry for the side track, but using terminology incorrectly is a minor pet-peeve of mine*
  9. HotH2o
    4,098
    4,865
    Sep 23, 2012
    What do you mean by "line haul"?
  10. Ghost Ryder
    1,647
    1,182
    Jan 3, 2013
    Your Mailbox
    DC to DC
    Something local would conclude that you never leave a metropolitan area, hence the short haul logging exemption.
  11. Sublime
    1,529
    1,896
    Jan 18, 2013
    Twin Cities, MN
    Doesn't matter what he calls it as long as he departs from and returns to the same location the previous five days he can use the 16Hr exemption.
    HotH2o Thanks this.
