Should I be worried about my driving?
Discussion in 'Questions From New Drivers' started by Icymac1234, Mar 4, 2024.
Thread Status:
Not open for further replies.
  1. Icymac1234
    Icymac1234 Bobtail Member
    Mar 4, 2024
    So at work I drive a 28ft box truck. Taking care of my tires is very important but I have times here and there where I’ll get into a tight turn and I’ll rub my tires against the side of the road. I was told I shouldn’t do it but I don’t know what else to expect from myself cause it’s hard for me to avoid it. So I get worried if I should even be driving trucks for a living. Idk if this is normal or if it’s a me problem. Any advice is appreciated thanks.
    Chinatown Thanks this.
  3. tscottme
    tscottme Road Train Member
    Maybe I misunderstand your question. If you are rubbing the tires against the vertical curb, you should not be. It's a good way to knock a tire off the wheel (instant flat tire) or damage the wheel and hub. Take more space to turn if it is available. If you want to be a professional driver you don't just let things happen. You set yourself/truck up to do things in a good manner. Sometimes you might have to run over a curb and you want to do that with the wheel rolling up onto it, the straighter the better, and at a very slow speed. Remember, that truck is your ride home. Don't abuse it. It's a long walk, even for a local driver.
  4. Lonesome
    Lonesome Mr. Sarcasm
    11,268
    23,174
    Dec 15, 2007
    Northern Indiana
    Swing a little wider on your turns, you should not be curbing tires.
  5. Chinatown
    Chinatown Road Train Member
    75,667
    173,123
    Aug 28, 2011
    Henderson, NV & Orient
    Swing a little wider and you'll be ok. Don't overthink and throw away a good career.
    Flat Earth Trucker and tscottme Thank this.
  6. silverspur
    silverspur Road Train Member
    1,688
    7,540
    Sep 26, 2012
    Aim high in steering.
  7. Ridgeline
    22,454
    117,603
    Learn how to drive a truck, you should never hit a curb.
    Flat Earth Trucker and wifi_guru Thank this.
  8. Allow Me.
    10,687
    12,271
    May 28, 2009
    Rancho Mirage, Ca.
    A 26ft box truck ? Need some practice. Are you driving mostly NYC ? Just curious.
  • Thread Status:
