Should I buy a Pete 379 or Freightliner Classic?
Discussion in 'Ask An Owner Operator' started by J8STARR, Mar 1, 2014.
  1. J8STARR
    J8STARR Bobtail Member
    17
    Hi Guys,
    I'm currently hauling 40 ft containers about 160km's one way. The loads are between 21,000kg to 25,000 kg. And once a week I will be hauling from toronto to new jersey. I am currently driving a 07 freightliner columbia 470 detroit 60 series 13 speed. I'm thinking of making the change in the summer to either a freightliner classic motor options 475 cat/ 515 detroit. My other option is a pete 379 with 475 cat or 475 isx cummins. Both 13 speed. I know hands down the pete is the better performer. But I also have to take into consideration Fuel. So my question to you all is how much of a difference is mpg between the 2 trucks? Would it be worth getting the pete or am I just spending way too much more on fuel?
    Thank you!
  3. rollin coal
    rollin coal Road Train Member
    13,304
    26,905
    Mar 29, 2008
    TN
    I'm voting for the barn door it's a known fact they get better fuel mileage than a brick.
  4. kw550cat
    kw550cat Medium Load Member
    663
    596
    May 22, 2012
    brooklyn, new york
    The Detroit will get the best mpg over a cat and isx. I would take a Pete because it looks nicer, but the classic makes a bit more sense. I know the Pete with a cat will do 5.5. The classic with a Detroit will get about 6.5. Mpg really comes down to how you drive. If you want a good looking truck that will always hold its value and be a timeless cosmic l classic, get the Pete. But if you are focused more on the bottom line, get the classic.
  5. Flightline
    Flightline Road Train Member
    2,345
    1,165
    Oct 1, 2011
    Almost There
    I was told about the same but bought a 379 pete with cat anyways and now get avererage 7+ mpg out of this pete. 379 pete get a bad fuel economy rep because most drive them faster.
    Though I do think a detroit 60 series is slightly better fuel effeciency motor. And freightshakers are cheaper to work on.
    exhausted379 Thanks this.
  6. Macneil
    Macneil Heavy Load Member
    711
    426
    Dec 15, 2010
    Sudbury, ON., Canada
    I have a 12,7L series 60 470 hp in my unit and I get far better MPG over two of our other trucks hauling similar loads/terrain/weight with a 470 cummins and a 475 cat.
    I prefer the looks of a Pete and would much rather drive a cat but if you're looking at the bottom line, go with the shaker with the detroit(or preferably cat) and go from there!!
  7. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,045
    May 13, 2011
    Middle Tennessee
    What's wrong with the Columbia (besides the obvious)?
    Anyway, Pete with CAT is my vote. Are these trucks sitting around for sale or are you gonna have to go hunt one down?
  8. dude6710
    dude6710 Road Train Member
    2,162
    622
    Mar 26, 2010
    MN
    Tune the truck you have and keep it because you could get much better mpg. No reason to get rid of a truck just because.
    BAYOU Thanks this.
  9. zero4
    zero4 Bobtail Member
    6
    Feb 26, 2014
    If you don't have any problems with your Columbia, I would suggest to keep it.
  10. truckereddy
    truckereddy Bobtail Member
    37
    7
    Feb 28, 2014
    highway usa
    wich one is the barn door? The classics have the same hood as the 379 well they look a lot alike. Is one really more aero then the other truck ?
    To the op classic are cheaper 379 looks better and hold their value more when trying to sell. I choose an aero truck but when I see a 379 I wish I did other wise just my 2cents.
    Passin Thru Thanks this.
  11. Passin Thru
    Passin Thru Road Train Member
    1,918
    565
    Mar 8, 2007
    VA
    I'd rather walk than drive anymore Freightliners. The ones I drove had gaps at the top of the door and bounced so high the stuff on the dash would fly off. See my pic? Truckereddy is correct? He gets a 100 on his paper!
    that65 Thanks this.
