Should I change the fuel-water seperator when I change the fuel filter?
Discussion in 'Peterbilt Forum' started by Mr. Cob, Oct 23, 2018.
  1. Mr. Cob
    Mr. Cob Light Load Member
    Howdy All,
    My gauges tell me that I have 75 psi of fuel pressure but the fuel filter restriction gauge has gone from the green zone to the red. I have a C-15 Cat engine which has one fuel filter and a fuel-water separator, so should I replace the fuel-water separator when I replace the fuel filter? Thanks for any advice you can give.
    Dave
  3. We are coming into the fuel blend change. It's always a good idea to swap out that filter and have one onboard
  4. Rideandrepair
    17,357
    56,318
    Aug 8, 2015
  5. Mr. Cob
    Howdy peterbilt_2005,
    Thanks for your quick reply. I figured it could do any harm so I am going to swap it out and add one to my list of spares, I have always carried extra fuel filters.
    Dave
  6. Slowpoke KW
    Slowpoke KW Road Train Member
    1,170
    12,825
    Dec 7, 2015
    OK
    I change the FWS first since it is the primary filter it will clog before the secondary. I generally change the FWS 3-4 times before needing to change the secondary . Just change the FWS, start the truck and see what the gauge says.
    peterbilt_2005 Thanks this.
  7. Mr. Cob
    Howdy Rideandrepair,
    Thanks, will do.
    Dave
  8. Mr. Cob
    Howdy Slowpoke KW,
    Thanks that is very good advise.
    Dave
    Slowpoke KW Thanks this.
  9. Slowpoke KW
    1,170
    12,825
    Dec 7, 2015
    OK
    It’s what I’ve been doing for the 6 years I’ve had my truck. And I carry spares of each.
  10. What year is your truck?
    If prior to 2012 check your fuel lines to pump and cross-over between tanks.
    Changing a fuel line to motor could help safe you a few bucks from starving motor of fuel. A lot of drivers neglect these lines as a truck gets older.
    bzinger Thanks this.
  11. Mr. Cob
    Howdy
    My truck is a 2001, it has the 6NZ C-15 Cat engine, as far as I know the fuel lines are clear but is something to check when I get back home about 2,000 miles from where I am now.
    Dave
