Should I drive with a broken fuel line?
Discussion in 'Experienced Truckers' Advice' started by Badmon, May 17, 2016.
  1. Badmon
    Badmon Heavy Load Member
    806
    1,503
    Oct 6, 2014
    Deep south
    I got one last delivery 12 minutes away. Diesel spraying all over the motor. I was advised not to drive by another driver. Should I do it?
  3. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    No,get it fixed like right now.If DOT sees that they will put you out of service then it will cost your company twice as much to fix it.
    justa_driver and MachoCyclone Thank this.
  4. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    Depends if you are O/O or co driver.
    2 weeks ago I was about 170 miles from home when I could smell diesel fuel, pulled over and saw fuel on the driver side of my N-14.
    Made it home & did deliveries next day, went to Cummins & got a new fuel line for $33 and had it installed in less than an hr.
    Just depends on what you gotta do.
    Big_D409, Hammer166 and againstthewind Thank this.
  5. spyder7723
    spyder7723 Road Train Member
    15,471
    25,075
    Mar 31, 2013
    sarasota, fl
    If it was me, id make the call based on how big a leak. Are we talking a seepage or are we talking a pressurized spray. Also what it was leaking on. Fuel plus 750 degree exhaust pipes is a bad combo.
    4mer trucker Thanks this.
  6. uncleal13
    uncleal13 Road Train Member
    3,797
    6,295
    Apr 9, 2009
    Humboldt, Sk
    Went from Beach,ND one time to Bismark fuel dripping from a return line by the tanks. Sprayed all over the trailer. Lost about a quarter of a tank.
    But in retrospect that was a dumb thing to do. Could have been an awesome fireball, and with that much fuel sprayed around might not of gotten out alive. Technically it's an out of service violation, plus the environment people could make it an expensive cleanup,
  7. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    Can you duct tape it or tie wrap a hose around the leak so it's not spraying and just dripping?
    Hammer166 and TequilaSunrise Thank this.
  8. Skate-Board
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    Even a rag around the leak
  9. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    Are you being serious??
    Is this a trick question?
    Hurst
  10. 123456
    123456 Road Train Member
    10,555
    5,747
    Oct 22, 2010
    32179
    Darn robot posters........
  11. 4mer trucker
    8,229
    259,551
    Nov 18, 2015
    At the least tie strap a absorbent towel/ cloth around it
    Fuel and high temps can be a firey situation
    Good luck
