SHUT DOWN in the mountain passes while driving!!
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Rolling18, Dec 10, 2020.
  1. Rolling18
    Rolling18 Light Load Member
    170
    34
    Dec 11, 2008
    Portland, OR
    HOLD ON SALLY!!... SHUTDOWN on mountain pass!
    WTF!!?????
    I'm fully loaded, going through some mountain passes, get the amber CEL. A minute later, I get the RED ! CEL... I am looking for place to pull over.. NONE! (2 lanes, no shoulder just snow packed dirt w/ metal guardrail. The engine shuts down!!!! BEEEEEEEPPP!! not a good time going down hill in curvy Mtn. roads..
    I had to super muscle it around the turns, any tighter curves would have been really ugly situation! no air compressor to refill brakes either...
    eventually coasted to a stop, mostly in the road on an uphill.
    anyway,
    IS there a way to disable this behavior of shutting down the truck regardless of the situation????
    this seems kinda..... ####ING DANGEROUS!!!:)
    6wheeler and Doealex Thank this.
  3. '88K100
    '88K100 Road Train Member
    1,490
    3,584
    Aug 23, 2020
    If it’s a Navistar answer is NO,,,get used to it. Sucks when you out passing on a 2 lane and the SOB does that.
  4. FozzyNOK
    FozzyNOK Road Train Member
    2,480
    3,824
    Jul 18, 2007
    Oklahomistan
    In the old days the truck would have just completely #### itself.. so at least the engine is saving itself.
    flood, lester and Just passing by Thank this.
  5. tallguy66
    tallguy66 Medium Load Member
    534
    873
    Oct 18, 2018
    My cascadia has an override engine shutdown button
    Blue Zombie Trucker Thanks this.
  6. Rolling18
    170
    34
    Dec 11, 2008
    Portland, OR
    The point in this post is not so much the engine saving ITSELF, but powering down the whole truck while still in motion and need ing the compressor to keep the BRAKES aired up and have steering ability..
  7. Rolling18
    170
    34
    Dec 11, 2008
    Portland, OR
    I have seen that in many trucks but this one did not have any override... (it doesnt even have trailer brake check valve)
  8. lester
    2,956
    8,085
    Jan 2, 2012
    NW, Iowa
    Well depending on why it shut down you may have been coasting anyway but with a grenaded engine. Loss of oil pressure or severe overheat. I doubt that was your issue, it is probably some stupid emissions problem but..
    TheLoadOut Thanks this.
  9. FozzyNOK
    2,480
    3,824
    Jul 18, 2007
    Oklahomistan
    If the engine would have thrown a rod through the side of the block.. how would it have been then?
    lester Thanks this.
  10. 6cuda6
    6cuda6 Light Load Member
    259
    176
    Oct 9, 2020
    Sadly its what happens these days ...overheat, low oil pressure, emission problem etc. Usually there is enough air in the tanks to get you to a safe stop but every once and a while a series of events makes it so that it just doesnt work out. Could be worse, on the vehicles we have, the driver has 30 seconds to get stopped if this happens or we stop the vehicle for them.
    All you really can do is stop and take a few minutes to verify everything visible [fluids, air etc] before you head into the mountains and hope for the best.
    Rolling18 Thanks this.
  11. LameMule
    LameMule Road Train Member
    1,148
    7,418
    Jan 19, 2020
    Montana
    Buy a mechanical truck...
    6cuda6 Thanks this.
