Side dump doubles as an owner operator
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by RushmoreTrucker, Apr 5, 2025.
  1. RushmoreTrucker
    RushmoreTrucker Light Load Member
    67
    57
    Aug 19, 2024
    Every little while, in South Dakota, for a couple weeks at a time hundreds of Petes and Kenworths with side dump trailers hauling doubles will take over the roads.
    Does anybody know what kind of pay they get as owner operators? How much dedicated equipment you need for side dumps? I'm currently aware that you need a wet kit, which dovetails in nicely with some other schemes I have to keep busy year round when I make the jump to O/O. Are drop axles necessary?
    Any details on the pay and equipment cost of getting into side dump, and especially side dump hauling doubles, would be appreciated. I'm pretty much evaluating whether I want to get into it before I start oilfield work. my current overall scheme:
    Power only postal/amazon/etc loads during dry times
    Oilfield water and other work when it's busy (I'm not super far from North Dakota. Two postal loads away, as a means of getting there and back home while being paid.)
    Side dumps during the periods when it is busy if it pays well enough to justify the equipment cost and the lower MPG
    Oilfield and side dump both require a wet kit (yes straight water pumps are an option but wet kit seems more versatile). I haven't researched pneumatic and other applications that require wet kits yet.
    Do not have a tractor yet, what I acquire will depend upon the feasibility of various parts of the business model.
    Thanks for y'all's knowledge
  3. North Pole Nightmare
    North Pole Nightmare Road Train Member
    1,010
    2,071
    Dec 15, 2021
  4. RushmoreTrucker
    67
    57
    Aug 19, 2024
    I don't know a ton, all I know is that they deliver to grading sites and also to places mixing concrete. Whatever it is, it keeps 500-600hp+ Petes at 55mph and many are pulling doubles with 5-7 axles.
  5. Arctic_fox
    4,489
    25,297
    Sep 16, 2016
    lot of rock, gravel and soil for building. I live up here and go to the same quarrys they do for landscapeing stuff. And i know a few of them if bones goes belly up for whatever reason. Not likely but i have a rolodex full of "oh #### i need a job" contacts lol.
    Anywho i run an end dump little diffrent then theirs and im not 100% sure on some of the minor details since side dump is something i have never done. But 99% of my truck is going to translate pretty well. First your going to need a pretty heavy duty truck. These fellers are going to be running likely upwards of 120k or more for the doubles. Brand doesnt really matter but see international HX620s, w990s, 589s, 379s western stars ect. They are typically better vocational rigs then say a volva plastic petey or weeny rig.
    550 horse minimum is what id recomend. Much less and your going to be a slow ### pig. You would likely want a double frame truck just because they are going to get beat to #### in rough conditions. Single will likely work if you get a heavier frame though. 13 or 18 speed are nearly required. Im going to say 3.72 gearing minimum. I have no experince with autos offroad save doing tanker and they sucked then. Cant imagine they are better for this.
    You need a wetkit. A pinable 5th wheel for the floating 5th wheel. likely a raised one too depending on the trailer. Full lockers and deviders are a must. Your going to want smaller sleeper or day cab to maximize weight you can fit on. Tall tires 11Rs or 24.5s for clearance. Tow bar or hooks on the front for sure. Trailers its going to vary depending on what you do though. Id recomend a longer wheel base like 230+ long. Mine is a 265 and is a little shorter then theirs. A drop axle will be a good idea as well. A 55 gallon hydralic tank for doubles. Going to want likely around 220-300 gallons of fuel capacity. You wont get to stop much/at all without screwing upnthe schedule
    Going to want to have a 4 pin connecter added for the drop axles on the trailers if equiped. Defo a good seat or your back is going to kill you on those rough roads. Going to need the right type of insurance too. These things cause issues if they go over. Same is true for side dumps. Id also avoid an emissions rig. They idle a LOT and a lot of stop and go. That said emissions can and do work, just plan to replace all your sensors, clean your EGR and DPF cans yearly. Or emissions lights galore.
    Pay wise id imagine its simular to me and they are paid by weight or cubic yardage. Call it around $2-3 a mile average equivlent. Maybe more, again never done side dump so cant say for sure. Though its a high pay job becauae of the costs involved.
    Figure for brand new equipment your going to be dropping around $300,000 minimum and used if you get the trailer $150K+
  6. North Pole Nightmare
    1,010
    2,071
    Dec 15, 2021
    They could be hauling spec sand for a cement plant ,or something similar.
    I hauled gold ore in Alaska,in side dump doubles.We carried the max weight we could for crossing some bridges,weighed 162,000.
    scythe08 and RushmoreTrucker Thank this.
  7. RushmoreTrucker
    67
    57
    Aug 19, 2024
    That's an absolute ton of equipment cost beyond the tractor. I wonder if I could get my foot in the door power only. When I start as an owner op, I'll reasonably be able to save about $40k and that's what I'll be able to do initially. (Not there yet, but that's feasible for me)
    There's a couple tractors in good condition I could get relatively cheaply (2006 pre emissions 9400i 10 speed manual with the engine recently replaced)
    Thanks for the information about 5th wheel, drop axle.
    What does the horde think about an APU? In the winter especially, I don't want to shut the truck off if I don't have an APU, and I REALLY don't want to idle a truck I own myself any more than I can avoid it.
    I know an owner op who does it seasonally, and he told me "10k/week when it's busy", which is oilfield level for potentially home every day. Of course expenses will be high... possibly higher than oilfield.
    Seeing entry costs that high, it might not be worth it.
  8. Long FLD
    Long FLD Road Train Member
    12,791
    53,478
    Mar 4, 2015
    The 20 axle side dump doubles are grossing around 200k pounds. A lot of the work seems to be pretty steady, you see a lot of trucks running all year. The guys hauling rock seem to stay busy stockpiling all winter.
    I’m not sure I’d want the expense of trying to do it with my own truck. It would be an insane amount of wear on parts. Not to mention you’d have to get it set up exactly the way the other trucks are to run the trailers. I’m not sure how stuff is ran, but they control 4 lift axles on each trailer from the cab.
    Blachowske takes owner operators and they have some 13 axle pneumatic sets. Not sure if they take guys only wanting to work during the construction season or not.
    There are also all the companies running 13 axle hopper doubles.
    The guys with the axles set the rates. And usually they don’t pan out all that much better than what you can make somewhere else without all the weight and axles. That’s why I’ve never really tried to live around home since I’ve had trucks.
    RushmoreTrucker Thanks this.
  9. RushmoreTrucker
    67
    57
    Aug 19, 2024
    Blachowske's terminal is super close to home, but from reviews working there is a terrible idea. Home time is a nice to have to me, I just want to be as profitable as possible.
    There are a couple companies that are hiring company drivers currently. I wonder if $27/hour with overtime outpaces my current convoluted pay structure of $27+5 for first 40 hours +5 for any hours on Fri, Sat, Sun... Probably not most of the time. But I'd get experience using a wet kit.
    I'm tired of the hiring process, but such is life in trucking.
    Funnily enough the place is literally across the street from my current job. It's incredible that dispatchers can make dedicated run mail hauling inconsistent.
  10. Long FLD
    12,791
    53,478
    Mar 4, 2015
    Not sure what Roth out of Rapid City pays their South Dakota drivers, but they have some trucks based in Sundance now and they’re paying $30 an hour for days and $35 an hour for nights.
    All I know about Blachowske is there’s a guy in White River that’s pulled doubles for them forever. And they have a nice loop down to GA and back for the highway guys.
  11. Sumtinlidat
    Sumtinlidat Light Load Member
    138
    425
    Dec 17, 2017
    Las Vegas Nevada
    Gonna have to say if you don’t have any clue about how side dump or agg work operates then stay out until you have an idea. I see so many guys come to our outfit here in Vegas wanting to lease on and pull our double sides/belly’s with the wrong truck. It’s like using a Toyota Tacoma to pull a gooseneck trailer and do hotshot. You can do it but you really shouldn’t. No one likes the truck that’s in the way. Most agg work is tonnage per hour. Basically your broker wants a certain amount of tonnage moved in an amount of time consistently. His hourly is based on an hourly rate divided by tons that can be hauled. You take longer and they lose money. In terms you get shorted also. You also need to be pretty mechanically inclined as how the trailers operate. No one’s sending a mechanic an hour away for some dumb shxt a driver did. You’ll have to know how to limp it back or fix on the fly. Most outfits help their own as they can but you will rarely get another company to stop and help. In agg work everyone is competition. What you fail to meet they will. And some will do it for less. Trust me when I say 400HP and a 10 speed will not make it in agg work. Especially doubles. Truck is too weak in all aspects for the work.
