Side windows vs no side windows
Discussion in 'Experienced Truckers' Advice' started by Kairidragon, Jul 1, 2012.
  1. Kairidragon
    Kairidragon Light Load Member
    55
    16
    Jun 17, 2012
    Where I Park it!
    We are going to be trading our truck in for a different truck in about 2 weeks. I have noticed that some trucks have big side windows in the sleeper area (not the ones up top) and other trucks don't have the side windows at all. The cascadia that we drive now has those very small windows that open and don't hardly let in any air flow at all. So I am wondering what the benefits/differences are of having the big side windows or no windows at all. I would think that without the windows it would get really hot in the sleeper area, but I could also see that without the windows less sunlight and heat leaking into the sleeper area. So if you guys could throw your 2 cents in about what you think, I'd greatly appreciate it! :)
  3. Gizmo_Man
    Gizmo_Man Road Train Member
    1,226
    599
    Aug 15, 2011
    Hardly around
    i think the side windows make for an easy escape in an emergency, over a solid wall.
    sleepers of years ago, actually had doors for escaping..!!! but those may have been the "sit-in" sleepers, and not the walk-in types.
    why some companies are not having "vent windows", i do not know, maybe a different company making the sleepers, maybe they have found that too many water leaks, or maybe they found that after X number of times, the hinges break and the windows fall out..??(which actually happened to me)
    Kairidragon and OSU Mike Thank this.
  4. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    The truck I drive has both upper vented windows and pop out side vents for the lower bunk. They do a decent job if there's a breeze but without one, it can get stuffy. It's not as bad when I use my Breezeway screens.
    I wish my truck had one of those sleeper vent fans that suck in air from the outside.
    Kairidragon Thanks this.
  5. PackRatTDI
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    The sleeper side doors were only required in the old sit in sleepers as the DOT didn't find the sit in space between the cab and bunk to be sufficient for an emergency exit, hence the sleeper doors. Plus before the mid 50's, there were sleepers that had NO direct link between cab and bunk, and the side door was the only access. Once the "unicab" sleepers came out, the requirement for a side door was no longer necessary as there wasn't a "barrier" between the bunk and cab, therefore leaving enough space for a speedy emergency exit through the front. Thats why cabovers never had those side doors, no barrier there either.
    I kind of miss having a sleeper door, made loading and unloading your gear a snap.
  6. Kairidragon
    55
    16
    Jun 17, 2012
    Where I Park it!
    Yeah I would love to have a vent fan too. Anything to keep from idling the truck so much. I've also noticed several trucks with the sunroof. I can't imagine that is a good thing. Sun beating down into the cab making it even hotter inside. Forget all that!
  7. PackRatTDI
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    I know, I have my skylight blocked off with cardboard. Even with the solar treated glass, the Texas sun still shines through. The sleeper curtain will block it off but I like keeping them tied back and using a front window privacy curtain.
    I remember the first gen Kenworth T2000s had skylights (Kenworth called them Aerodyne windows IIRC) that unfortunately were installed where they were BEHIND the sleeper curtain, not in front. Later versions eliminated the skylights altogether.
  8. Kairidragon
    55
    16
    Jun 17, 2012
    Where I Park it!
    I just love the kenworths! Unfortunately it not going to be one of our "available truck options". Going to have to decide between a freightshaker, a volvo, or a prostar. :( We drive the freightshaker right now. I'm leaning towards the volvo for our next truck which is brought up my orginal question in the first place. I've noticed a lot of the volvo's without the "vent windows" and i like to be able to open all the windows on cooler nights if not just for the fresh air! LOL A lot of them also have the skyroof. Guess if it has a skyroof, we'll implement your idea of covering it with cardboard
  9. PackRatTDI
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    The newer volvos traded the upper tip out windows for some sort of vent. The glass is fixed and I guess theres a small door behind that grate area that lets in air. Never had the chance to poke around my father in laws new 2013 Volvo to see how it operated. The lower windows still tip out in the big 770 and 780 sleepers.
    I kind of like the Prostar windows, they seem to allow a larger airflow area.
  10. hhmag70
    hhmag70 Light Load Member
    103
    59
    Mar 18, 2012
    Trevorton,Pa
    I found the large side window on a W9 sleeper to be handy when blindside backing as I could just cheat and look through that window for better view.
  11. OSU Mike
    OSU Mike Bobtail Member
    14
    Jun 19, 2012
    I know that the Kennworth "coffin" style sleepers have air vents and fans to suck in the air.
