Signal flasher
Discussion in 'Volvo Forum' started by krob400, Jan 8, 2014.
  1. krob400
    krob400 Bobtail Member
    Hello everyone, I'am trying to locate the signal flasher on a 1998 Volvo VNL. Can anyone help with this. So in other words, where is the dang thing located on the truck?? Thank you.
  3. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    It's under the panel where your CB mounts. Take that panel off and you'll see the main fuse panel under it. The flasher unit if I remember correctly is the very top right...FL1 Flasher.
  4. krob400
    Thank you CondoCruiser, I will check that out this morning.
  5. bowtieboy77
    bowtieboy77 Light Load Member
    274
    82
    Aug 16, 2013
    Southern, Ontario
    I believe condo is right it looks just like a regular relay so don't be fooled and a mechanical flasher will not work in it it has to be a solid state flasher.
    krob400 Thanks this.
