Signal Lights...
Discussion in 'Questions From New Drivers' started by Ralston Rosas, Mar 30, 2021.
  1. Ralston Rosas
    Ralston Rosas Bobtail Member
    4
    I bought a 2006 international 9400i last week.(my first truck) It has a c13 with a 10speed Eaton. When I hooked it up to a trailer. I turned the the left signal light on and all of the lights on the trailer started flashing(including the running lights). I pulled my plug out of the trailer and put a test light to it, the left turn, right turn, and running lights were flash. I unplugged my calve from the back of the sleeper and put my test light to it..same thing. I replaced the signal light unit on the steering column, the flasher relay, and ALL of the fuses that had anything to do with light. Still the same thing. I checked all of the grounds. Nothing broke. Definitely need some help. I wish I had the funds to take it to a mechanic shop. But I do not.
  3. lester
    2,920
    7,890
    Jan 2, 2012
    NW, Iowa
    Take the plug apart on the truck side and see if there's some bare wires touching. Or follow the cord and see where it goes and check there. Think you probably just have some bare wires somewhere
  4. 062
    062 Road Train Member
    6,216
    33,464
    Oct 20, 2013
    While looking for wires touching if you see a lot of green crud clean it up. I’ve seen corrosion bad enough to complete the circuit.
    Roger McG and lester Thank this.
  5. Ridgeline
    22,401
    116,479
    Chances are you have a bad cab control module (CECU).
    the dealer can be the only one to tell you.
  6. lester
    2,920
    7,890
    Jan 2, 2012
    NW, Iowa
    I don't know anything about internationals but I didn't figure an 06 would have one of those. Not that I know much of anything about CECUs either
  7. abyliks
    abyliks Road Train Member
    3,890
    9,091
    May 2, 2010
    ludlow MA
    Did you try a different trailer?
    RockinChair Thanks this.
  8. Ralston Rosas
    4
    So behind the plugin(inside the tool box/sleeper) there was three sets of wire connectors. I unplugged one of them and everything on the truck started working normal. But there is no power to the plugin points now..
  9. lester
    2,920
    7,890
    Jan 2, 2012
    NW, Iowa
    Did you take the truck plug apart and check it?
  10. Ralston Rosas
    4
    Yes I pulled it off and cleaned it up. Nothing was loose or broke. Just a bit of dust. But nothing that would hurt.
  11. wis bang
    wis bang Road Train Member
    3,393
    3,996
    Jan 12, 2011
    Levittown, PA
    Something is feeding back, check for damaged lights, mangled license plate light and any wiring that looks like it wasn't repaired properly.. Somewhere you have two wires touching
    GreenPete359 Thanks this.
