Signs that you will have DPF and emission problems?
Discussion in 'Ask An Owner Operator' started by jpeters72155, Mar 16, 2015.
  1. jpeters72155
    jpeters72155 Light Load Member
    219
    18
    Sep 17, 2014
    Beautiful weather here in CA starting but now time to face one of the things we pay for all that nice weather - crazy regulations! Some of you might know I'm looking for a couple trucks. I found out quickly how horrible the used truck market is for day cabs with emissions tech filled engines. Right now I'm wondering )and this would be useful to those also looking for over the road trucks) how can you tell if a used truck will have future emission problems?
    The service records on some used trucks say Removed, replaced or cleaned Diesel Particulate Filter and they say nothing else about emission components or work. I'm looking at 2011-2013 Freightliners.
    I know the filters have to be cleaned every so many miles. But if it has been replaced isn't that a sign of future problems? That's what I got from the forum research. I know a knowledgeable person can look at the truck and try to make a call but what would they be looking for exactly? What are some of the signs of emission problems or related emission problems to look for besides a DPF being replaced? I work for a small company that's working their butts off to stay competitive but doing it the right way. I really appreciate the help. Thank you guys.
  3. jpracer1
    jpracer1 Medium Load Member
    439
    198
    Nov 26, 2009
    I would say if it says year model 2007 or newer,it will give you potential problems,thanks to California for creating this mess
    rank, Cetane+ and Joetro Thank this.
  4. Balakov100
    Balakov100 Road Train Member
    3,938
    2,641
    May 10, 2012
    Temple, TX
    Does the ECM keep track of Manual Regens?
    Normally they shouldn't require a lot of them.
    Daycab/Local Work might change that a bit.
  5. bubbanbrenda
    bubbanbrenda Road Train Member
    1,388
    650
    Feb 27, 2011
    Middletown,Oh.
    Anything with 200,000 miles or more are going to need repair/maintenance. And the dealers will NOT do it correctly, they do just enough to make it legal the day you drive it off the lot. Try to get a FACTORY/DEALER (not aftermarket you have to pay for) warranty for at least a year that includes ALL after-treatment parts and labor IN WRITING do not take anyone's word for it. If they don't believe in their equipment why should you?
    Cetane+ Thanks this.
  6. brian991219
    brian991219 Road Train Member
    2,956
    5,958
    Aug 10, 2013
    Lords Valley, PA
    IF it has a DPF it will give you trouble. In all seriousness, it is a crap shoot on a used truck, all it takes is one leak in the EGR cooler to put antifreeze in the EGR system which will cause soot to stick to everything, plugging up the system and causing long term problems. Good advice above, check on the number of manual regens if possible, look for sensor replacements as these should be done when the DPF is baked (cleaned), see how many times the EGR cooler has been changed, if it has been more than once you may have a continuing problem.
    Stay away from the International Maxxforce motor at all costs, the Cummins ISX is ok but check the EGR cooler they are known for failures, the DD is an ok motor but is known for sensor failures, but at least they are cheap and easy to fix, the EGR cooler gets expensive, especially if you have to fix down stream problems.
  7. roadtech
    roadtech Medium Load Member
    391
    920
    Sep 4, 2010
    Northeast
    The potential for problems with DPF /DEF trucks is almost guaranteed.Especially with anything over 200k as previously mentioned. You should be able to get an ecm printout from the dealer and see if the truck was run hot, low coolant warning codes (potential EGR problems). If the filter was replaced it usually meant there was a crack found in it and that could be due to improper or overly hot regens. I was told at the local KW dealer to replace a DPF ceramic filter with parts and labor was close to $4k .
    Warranties help with the cost of repairs,but it does not change the fact that the truck will be making frequent trips to the dealer and losing money . I don't envy you having to have a current emission compliant truck to operate in CA.If the truck will be idling a lot or in stop and go traffic it is horrible for these engines and they will constantly be trying to regen . You can't look at trucks after 2008 as you look at non DPF/ DEF trucks as they ask the engine to be an engine to move the truck and a Soot Furnace.Do not believe what the dealer sales people tell you ,they have to say whatever they have to say to move that iron off their lot. The mechanics and service managers are limited to what they say as they could get in hot water telling a customer or potential customer what they Really think about the issues with current emissions equipped trucks .Talk to towing companies and they will tell you they tow in way more newer trucks due to emissions /engine related issues than they tow in pre 2008 trucks .
    Also go to independent diesel repair shops and ask their opinion ,you will get a way different answer on the topic of newer trucks than you will from a dealer trying to sell them.
    brian991219 Thanks this.
  8. Fajo
    Fajo The Dark Knight
    2,214
    2,352
    Jan 26, 2013
    Boise, ID
    I have a 2011 Prostar International with 477k on it and it had to have the DPF filter replaced 100k or so ago. The new filter that Cummins makes has bigger holes and does a better job with less, the cummins tech said the redesign filter should cut the emission problems down drastically. In 100k I have had none and the truck has ran strong.
    Hope this helps somewhat.
    EZ Money Thanks this.
  9. Kujo
    Kujo Medium Load Member
    442
    168
    Feb 6, 2012
    in the middle
    Idle time is worse then mileage. High idle time causes way more wear and tear then driving because the engine isn't hot enough to passive regen. And as everyone else said after 200k they start needing more repairs. Once the dpf is cleaned and the def doser is cleaned they should be good. But that really needs to be done every 100k to keep it going.
  10. EZ Money
    EZ Money Road Train Member
    Also if it is a Cummins they used to state in the owners manual that every 250k the DPF needs removed and cleaned.
  11. JPenn
    JPenn Road Train Member
    1,829
    1,874
    Mar 5, 2008
    Northern Tier PA
    Sadly, the biggest sign that you will have DPF/emissions issues is that you bought a truck so equipped in the first place. I've got a fleet of trucks with assorted varieties of Cummins ISX, from 450 to 525 hp, and it's a never ending issue. There is not one week out of the year that I've been here that we have not had an emissions-equipped truck in the shop for an emissions issue. Cummins' EGR coolers are a recurring theme, with some trucks on their second in under 200K miles.
    Makes me really appreciate the lone Cat powered truck...a '94 T800 with a 4CK 3406!
    roadtech Thanks this.
