I know the answer is most surely YES but... I have to ask. I have a problem with my parking break on my standard 1 Ton pickup truck with trailer. The dam mechanic charged me $400 and never fixed it right and now I am in a situation where I need to take my truck to make some money. Will the DOT pull the truck out of service if the PARKING break does not work. Even tho the truck can be put in gear when off and not roll away? and is there anything I can do to get around this??? I have to make some money to pay my insurance and between incompetent mechanics and the weather here I have been paying for insurance since the 6th and not used it yet.. Any Input would be great..
Silly Question about DOT and Breaks
Discussion in 'Questions From New Drivers' started by thereverend, Mar 20, 2014.
describe the problem, parking brakes are easy to adjust. Maybe we can help you to fix it... LoL $400 phew.......
if your mechanically able. crawl under there and adjuist your cable. and if your truck has holes in backing plates on the back brakes. at the bottom. wouldn't hurt to take a screw driver and adjust the rear brakes also. if you've got a low brake pedal.
can't swear by dot. but in utah. no emergency brakes is failure on safety inspection. and you can't get your car or pickup licensed till it passes safety, -
Yea I would have been happy if they worked after the $400 but... they don't... I know that new shoes were put on. But when I left the garage I went about 5 miles down the road and parked put the parking breaks on to see how they felt etc when you put them on after they were done and the truck just kept rolling in the parking lot.. Had to put it into gear to park it. Called the mechanic and brought it right back to him this is the part where he decided I did not need a passenger side mirror and tore it off trying to get it into the building. AS pissed as I was I figured 'you get more bee's with hunny' and simply allowed him to offer to repair it and he did but quickly escorted me out of the garage into the waiting room. Then went back out to the garage for a few min and came back.. He told me that my PIN holes in the backing plate were elongated and the pins were missing and I need now to get new backing plates $385 EACH SIDE (they come loaded with shoes etc) I asked if he could do anything that day and he said no you have to come back to get it fixed now its been a week and the Mother trucker I not answering my calls/texts etc.. I am livid and will most likely have to sue to get my mirror fixed and my breaks fixed correctly now.. This guy appears to not know what the hell he is doing... I need your Input what if anything can I do to make this work for a little while for me if in fact these 'pins' are missing?
You're in a pickup. Odds are if you are not overweight, they will never bother you.
If you plan to be successful, you'd better be prepared to get your hands dirty. Otherwise you will be out of business. Brakes are extremely easy. You already had 2tell you in 3 posts about adjusting the parking brakes, but for some reason you don't want to hear them. Your mechanic ripped you. You brought the truck in, said brakes, and he saw a sucker. He purposely left them out of adjustment.
Go go to Harbor Freight and get some tools. Go find a Haynes manual. Adjust the brakes.NewNashGuy Thanks this. -
I will try to adjust the breaks today myself. I did hear you on that part and have every intention of trying to do it myself with the adjuster screw. I was just wondering if there was any legitimacy to this PIN thing he was talking about or if he is just blowing smoke up my stack.
On the inside of your truck, release the parking brake. Jack the truck up by the rear axle, and put a stand underneath to support it. Remove the wheels. There should be a hole at the bottom on the back to stick a screwdriver in and turn this gear thing to tighten the parking brakes. Loosen it. The brake drum should slide off. You should see the brake shoes held on to either side of the wheel hub by springs. You should also see the brake cable attached. Simple stuff. If there was something wrong or something missing, your mechanic would have never put it back together. Even a rotten mechanic wouldn't. Lawsuit and a half. Now put the drum back on and adjust the parking brake to keep the hub on. The wheel should be able to spin freely, but when you pull the brake cable, you should feel good tension.
Ok.. I will see what happens today when I give it a try. Ill keep you all updated. I hope he did not forget to do something or left it out on purpose.. but it would not surprise me.
(I miss spell and typo all the time so its ok lol)
I'm assuming these aren't air brakes on a 1 ton. Unfortunately, using the trans as a brake is never an approved method. Its not a bad idea if the other brake fails as a back up, but still not approved as the only method. When working on your truck, you chock the wheels instead of just leaving it in gear. If you ever need to park on a hill, I would never trust the trans to hold it, although it cant hurt as a back up.
All this being said, how often do you get dot inspections? In my history of driving a commercial vehicle, I have never had a dot officer check my braking systems. As long as you get it fixed in time for your annual inspection, you should be alright. Make sure you keep your truck clean and you lights in working order so they have no reason to check you further, but on a 1 ton, you should be ok until you get it fixed. Carry some tire chocks just incase you need to park on a hill for your own piece of mind. -
Your 1 ton is subject at any time for inspection on any roadway. Your parking brake needs to hold when you put it in gear or you can be put out of service. This is why I don't own a 1 ton truck and never will. If my 2500 can't pull it I don't need it.
