Anyone has a fuse diagram for 2012 Pete
12 volt lighter where the tv is OUT
passenger side in sleep bunk
bunk
i know there's a fuse box in the glove compartment
not sure which fuse fixes that
anyone can help???
Simple Help needed-peterbilt 587
Discussion in 'Peterbilt Forum' started by Infamousss11, Jul 31, 2013.
Flip the lid over
Give me the chassis number. The last 8 and I'll get it for you.
Sorry but you may have to hit me 10 more time,s for answer! there is another fuse panel in the right side storage compartment but i have found that many of these units were built with the wrong wiring plugged in. (lighter 1 and 2 ) in front cab!
i have 20 of these units up and running , but have yet to figure out some of these problems as some fuse locations are hand written n location keys on the lower schematic
Please check all fuses with DMM and then check location!
also check socket to outlet plug as i have found some plugged side ways, crap with out no ground this stuff will not come to life as advertised. hit me if i can help, rogue -
