Single axle weight limits above 20K lbs.
Discussion in 'Questions From New Drivers' started by MACK E-6, Feb 14, 2022.
  1. MACK E-6
    50,142
    239,543
    I recently had something pointed out to me with regards to axle weight limits where apparently you’re allowed more than 20K on a single if your registered gross is below a certain amount.
    Here’s where I got that.
    Compilation of Existing State Truck Size and Weight Limit Laws - FHWA Freight Management and Operations
    According to this, MD for example will allow 22,400 on a single axle if your registered gross is below 73K.
    Now the question I have is this. Could this be applied to an 80k registered single screw pulling a tandem long box even though with that combo you’re not allowed to gross that much due to only having 4 axles?
  3. ZVar
    ZVar Road Train Member
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    Make sure the axle weight and tires allow more than 20k on the axle. Otherwise it doesn't matter what the state weight limit is.
  4. motocross25
    motocross25 Road Train Member
    3,893
    11,967
    Sep 23, 2010
    Overland Park, KS
    I dunno anything about it first I’m seein it @MACK E-6 but while we’re cracking eggs of knowledge maybe you can break one on me. Some of those states have stuff listed about an “NN route”. What’s an NN route?
  5. ZVar
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    National Network route
    National Network - Wikipedia
    In a nutshell, truck routes.
    motocross25 Thanks this.
  6. motocross25
    3,893
    11,967
    Sep 23, 2010
    Overland Park, KS
  7. ZVar
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    I want to say yes. Maybe someone who knows better can answer.
  8. MACK E-6
    50,142
    239,543
    How does the state limit not matter?
  9. ZVar
    10,911
    23,833
    Sep 10, 2010
    Flint, MI
    Because if the mechanical rating is 20k, that's the weight rating max. Doesn't matter if the state allows 50k, if the equipment isn't rated for it.
    The max weight per axle has always been which is lesser.
    1. State regulated rating.
    2. Axle weight rating.
    3. Tire weight rating.
    GreenPete359 Thanks this.
  10. Moose1958
    Moose1958 Road Train Member
    15,298
    33,966
    Dec 17, 2010
    Williesburg, Virignia
    I am not 100% sure. However, in common parlance, STAA means doubles. The way I understand it doubles is allowed on all of the National Network roads PLUS up to one mile away from one in the case of a double. This is why you will see many "drop yards" very close to roads in the National Network.
    In all honesty, I have no idea what the "legal" difference between NN and STAA is and honestly don't care. I just have always thought of STAA as doubles.
  11. Hammer166
    7,610
    27,822
    Aug 18, 2007
    ~8600+' and loving it!
    Nope. It plainly specifies registered gross weight not actual gross weight. And based on the horror stories I hear about your Maryland DOT, I don't believe I'd be risking that one.
    MACK E-6 Thanks this.
