Single, Duals, or Floater for Tag Axle
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Blind Driver, Jul 4, 2014.
  1. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    I have noticed all three on tri-axles near me.
    Which do you prefer and why?
  3. lobes1985
    lobes1985 Medium Load Member
    306
    112
    Aug 9, 2009
    Wappingers Falls, NY
    I don't have a preference. The truck I run now has duals. My last truck had a 385 single and Ive run ones with a 315 single. I don't notice a difference between them. Everyone in NY will soon have single because they are requiring all lift axles to have a "steerable" or axle that that tracks with the truck when turning and duals don't work with that.
    The different setups usually come down to weight. A larger single can be for a 20k lb axle where a 315 would be on a 18k lb. Duals are good for 20k also.
  4. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    guessing due to being in the tanker/dump forum were talking pushers for bridge not for permitted loads. witch in that case single's with a steerable is the best choice. in my oppion
  5. 201
    201 Road Train Member
    12,236
    24,971
    Apr 16, 2014
    high plains colorado
    Years ago (70's, early 80's) I pulled a 28 ft. dump trailer, and the tag axle ran car tires with an air lift. Seems in Wis. there was a loop hole in the law, that required a tag axle to haul 75,500lbs gross( 72,500 without) but they never said what kind of tires or brakes were needed. Everybody picked on me, calling them "training wheels". ILL didn't recognize that axle, so still had to haul 72500lbs. when I went to ILL. and they'd hang low, at the toll booths(paid by # of axles), sometimes I had to get out and spin them so the toll operator knew they weren't touching. Later, Wis. changed the law, requiring the tire had be full size and have it's own brake.
  6. Blind Driver
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    Seems to me that a single would only be allowed to haul half the weight of duals or a floater. But here a tri-axle can haul 68,000 and a quad 73,280.
  7. abyliks
    abyliks Road Train Member
    3,835
    8,935
    May 2, 2010
    ludlow MA
    I believe the floats ride the best , the tri axle roll off I drive has 425s on the front and the tag and it's like driving my couch down the road, in ma were allowed 77,000 with a 6% grace if we don't have a scale ticket,
