Single frame superliner dump?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Dino soar, Jan 25, 2018.
  1. Dino soar
    Dino soar Road Train Member
    4,807
    26,922
    Dec 8, 2017
    I was just wondering if anyone knows if any of the 80s Mack superliners were ever originally made with a single frame.
    I found a tri axle dump truck with a single frame that has apparently the heavy axles under it and all of that but I don't know if it was converted or if any of them originally came out with a heavy single frame.
    I'm sure someone out there knows the answer to this.
    Thank you.
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    I had an 81 that was a single frame,used it to haul crude oil.
  4. Dino soar
    4,807
    26,922
    Dec 8, 2017
    Was it a factory dump truck?
  5. W900AOwner
    W900AOwner Heavy Load Member
    714
    1,284
    Jul 2, 2014
    I'd go on bigmacktrucks.com site Dino soar...those guys are all die hards there that wear bulldog underwear. There'll be plenty of guys there to answer whatever you need or want to know about a Mack from an AC to a Titan.
    Dino soar Thanks this.
  6. bigguns
    bigguns Road Train Member
    2,846
    6,854
    Jun 13, 2013
    Omega,GA
    Can’t a dealer run the vin and come up with the original specs?
  7. Dino soar
    4,807
    26,922
    Dec 8, 2017
    I will definitely check bigmacktrucks.
    I didn't know if Mack would look up a VIN for you, or if they even have any information on something that old.
    But that's worth a shot.
    W900AOwner Thanks this.
  8. W900AOwner
    714
    1,284
    Jul 2, 2014
    Now that Mack is Volvo, I have my doubts that they'd even take the time to help look up something that old, unless you stumbled across one of the dinosaur parts men there that are willing to dig into it more than the newbies.
    I have 40 year old equipment and have a stand-by team of "gurus" I use in different capacities of truck parts and salvage yards to help locate obsolete things as I need them. Most of the new guys won't look past the monitor screen, while others with some age will be happy to dig into the archives...that's what I have experienced. It is getting harder, but as long as there's a few good men left in the business, it will still be OK.
    bigguns Thanks this.
  9. Dino soar
    4,807
    26,922
    Dec 8, 2017
    Everyone should be able to run 40 year old equipment.
    I'm all about 40 year old equipment, and I even have some that's older than that.
    Way better than the junk they have nowadays.
  10. Dirty-Low-Walker
    Dirty-Low-Walker Medium Load Member
    359
    543
    Dec 17, 2013
    Heavy Rears?
    If its a 80's Mack and it has heavy Mack Rears they are either 44K or 58K, they both have a cone in the center of the outside of the axle, if they are 58K rears they came with 11/24 tube type rubber and have larger cones, either way i have never seen a Mack factory dump truck with those rears have a single frame, i am more farmiliar with the Rd686SX and the later RD 688SX, both had heavy rears and double frames.
    The serial number and the letters after the model will tell you the identical spec of that truck, SX stands for extreme duty, Superliner was different then the RD, if its a RW713.................letter after that will tell you.
  11. Dino soar
    4,807
    26,922
    Dec 8, 2017
    I have to go back and check on that truck. I have been looking at other trucks and I got away from that one.
    It just sounded odd that a superliner of that era could have a single frame and be a factory dump truck.
