Single Sideband
Discussion in 'CB Radio Forum' started by squirrellsgnwild, Mar 23, 2009.
  1. squirrellsgnwild
    squirrellsgnwild Medium Load Member
    Do you need a license to talk legally on ssb?
  3. HTDemetrius
    HTDemetrius Bobtail Member
    20
    Mar 11, 2009
    Lansing, MI
    On the normal 40 channels you do not need a license to use single side band.
    squirrellsgnwild Thanks this.
  4. JSmitty
    JSmitty Light Load Member
    288
    52
    Feb 22, 2009
    Midland Tx
  5. squirrellsgnwild
  6. JSmitty
    288
    52
    Feb 22, 2009
    Midland Tx
    Because alot of times, it depends on conditions. Also, alot of drivers such as I, like to run a little bit of echo/reverb, and these do not sound good on SSB. They sound good on AM if adjusted accordingly.
    I talk quite a bit of skip on SSB (27.385 lsb & 27.515 lsb), when conditions are good for long distance. By long distance, I mean Texas to Jamaica, or from coast to coast.
  7. squirrellsgnwild
    what is your rig and how many watts you using?
  8. 25(2)+2
    18,756
    45,804
    Sep 18, 2006
    the road less travelled
    If the skip is rolling, the CB band will go hundreds or even thousands of miles with very low power, no amount of power will force long distance communications when the skip isn't going.
    I have talked barefoot, mobile to mobile, over 1000 miles.
    Sideband is less congested, and you don't have the carrier waves all clashing, so it is more useful.
  9. Coonass
    Coonass "Freshy Fresh"
    1,080
    1,179
    Sep 23, 2008
    Are you all talking about upper and lower sideband?
  10. JSmitty
    288
    52
    Feb 22, 2009
    Midland Tx
    Yes, he and we are referring to upper & lower sideband (SSB).
    As far as my current setup, it's a Galaxy 99V, Texas Star DX 1000, Predator 10k antenna, and an Astatic 636L mic ;)
