sirius antenna not detected
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by akira, Dec 19, 2010.
  1. akira
    akira Bobtail Member
    5
    Oct 25, 2007
    Indianapolis,IN
    Had my sirius sporster for 2 years now without moving it or the antenna!thinkin of just buying a new system...love my satellite radio
  3. bullhaulerswife
    bullhaulerswife Forum Leader/Admin Staff Member Administrator
    28,290
    44,440
    Jul 23, 2007
    Midwest
    We had the same problem and we bought a new antenna and problem solved. So you might just need a new antenna.
  4. Kansas
    Kansas Road Train Member
    2,541
    2,585
    Apr 14, 2009
    aircap, Ks.
    That happened to me, ended up that the antenna wire had become cut where it feeds through the door.
  5. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    I had that happen on an older unit, called Sirius and they gave me a big story on how something might have broken inside the radio, it was not worth fixing, buy a new radio. Put on a new antenna, and has worked fine ever since!
  6. REDD
    REDD The Legend
    6,237
    4,291
    Jun 29, 2009
    Dueling Banjoville
    Buy a wilson antenna.
    The cable is much more superior then the stock antenna's
  7. Shiftin
    Shiftin Light Load Member
    280
    108
    Sep 2, 2010
    Central-New Jersey
    Would the antenna from my 4 wheeler do fine or should I get the ones that mount on the mirror from the TS for my rig?
  8. REDD
    REDD The Legend
    6,237
    4,291
    Jun 29, 2009
    Dueling Banjoville
    The little 4 wheeler antenna works fine for me
  9. sidewinder
    sidewinder Bobtail Member
    28
    6
    Apr 4, 2008
    LaGrange ga
    same prob with mine, was the antenna.
  10. Flying Finn
    Flying Finn Heavy Load Member
    972
    557
    Jun 22, 2010
    Ontario, Canada
    The antenna connection that is surface mounted to the PCB in the radio has a flaw. very little solder and small contact area. What happens is that over time with the vibrations in a truck the solder lets go. Then the connection becomes intermittent. This happened to my old unit. I had a second one from a major sale so I just switched my plan to the new one.
    I decided that since I officially am an Electronics Engineering Technician, at least that is what my college diploma says, I would check the internals out. That is the exact issue I found. Seems like a weak spot in manufacturing.
    Seeing as we put 10 years of mileage on a vehicle in a year it ends up being the same amount of abuse to these radios. So, if it lasted 2 years OTR then you got 20 equivalent years of use out of the same radio. Although I highly doubt that these radios would actually last 20 years of use in any environment. If only I could find the box with all my electronics equipment in it I could fix it pretty easily.
  11. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    The wire fell out of the bottom of my Wilson antenna. I haven't fooled with it since I got a factory satellite with the new truck. I think I can solder it back in, but still...
