Sirius XM Radio Antenna Mount
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Neptune, Jul 8, 2015.
  1. Neptune
    Neptune Bobtail Member
    5
    hi guys i would like your guys input on how you would run the wire with out pinching the wire i plan on taking double sided tape and mounting it to the mirror
  3. marineman227
    marineman227 Dock Waterer
    600
    796
    Jan 26, 2008
    Neenah, WI
    Your truck or company truck? Are you allowed to open it up at all?
  4. Neptune
    5
    i dont know i might see if they will install it
    that way i dont get in trouble
  5. goblue
    goblue Road Train Member
    1,586
    789
    Dec 23, 2012
    Grand Prairie, Texas
    Mounted mine in headliner above passengers side upper cabinet. Stick magnet to pickle jar lid and slide under headliner where it meets under cabinet. Run wire down to top of passengers door window across to and behind piece where Jesus handle is and then under glove box. Best reception I've had so far...
  6. AModelCat
    158,556
    I've never installed a satellite radio in a large truck but when I installed one in my pickup truck I ran the wire behind some dash trim then up behind the rubber door gasket up to the roof. I had it like that for a couple years without issue. I got much better reception than my other truck with factory installed satellite radio.
