Size of my tanks?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Randy Redbeard, Apr 11, 2019.
  1. Randy Redbeard
    Randy Redbeard Bobtail Member
    4
    I was assigned this 2019 Kenworth t680 with 65k on it. All the paperwork that came with the truck is in the truck. Problem is I can't find anything that specs the fuel tanks. I've pulled in on e and only pumped in 150 gallons. But I find it hard to believe this thing was ordered with twin 75s... . How do I know for sure the size of my fuel tanks?
  3. IH Truck Guy
    4,417
    50,680
    Mar 2, 2008
    Purgatory
    Should be stamped around the neck or a tag on the end will have the capacity.
  4. Newto Trucking
    Newto Trucking Medium Load Member
    359
    225
    Dec 26, 2013
    NE Illinois
    Hey Randy you most likely have 100 gallon tanks, they only can hold 95 gallons. Pick up tube in a tank is in fixed position and it will take 20 gallons to get just above this tube in each tank, if they would go all the way to the bottom they would pick up all the dirt and such from the very bottom of the tank. So it makes 40 gallons for both tanks like a reserve fuel and you were 10 gallons away from reaching it and stalling the truck on a side of the road. Always top it off as much as you can in the tanks then it will be 190 gallons total.
  5. kakk86
    kakk86 Light Load Member
    104
    37
    Jul 16, 2017
    Virginia
    Most I've ever put in my 2018 t680 is 145 gallons and it was right on empty.
  6. Moosetek13
    Moosetek13 Road Train Member
    14,726
    18,546
    Nov 1, 2010
    Burnsville, MN
    In my Cascadia I don't really start to worry until 100 miles after it hits zero.
    If I'm really heavy.
    When it indicates 1/2 about 70 gallons will top it off. At 1/8 I can put in about 130.
    2 100 gallon tanks.
    I call for fuel more often than I use the assigned fuel stops because the computer always thinks I have way less than I do, and I hate wasting my time to get 50 gallons.
  7. Teasa
    Teasa Bobtail Member
    4
  8. Teasa
    4
    I slip seat at a yard with trucks that some are route trucks. 2 truck I could use 1 was broke the other is on empty and it was Sunday. I took the getting one and thought you could drive under the empty line and took the empty trailer across street for load then bobtailed to get fuel on the kenworth with duel tanks. 194.176@ 659.92 was stupid now and could have got fired but made it loves 5 miles away
  9. AModelCat
    160,479
    Sounds like scab company if they'd send you out in a truck with no fuel in it and then fire you if it ran out.
    I don't know why people/companies make such a big deal out of little crap like that. We had a driver years ago run out of fuel 600 feet down the road from the yard. Not even an issue, I just ran down the road with a pickup and slip tank, threw 15 gallons in the tank and sent the truck on its way to the cardlock. Hardly even worth getting upset over.
    Sons Hero Thanks this.
  10. Teasa
    4
    Yes seems the only good companies are gone and filled up. I hope they wouldn't fire me but turnover is so high and write up a so many especially with the new driver facing cameras that watch all the time and the governor is so annoying that cars pull so close they mess with the camera, brakes and put fear in everything.they car and pickups play, especially when they push you in the left lane and not let you back.
  11. Teasa
    4
    I think tanks are usually 2@ 120 gal and 50 miles under e
