Skip shifting an 18 speed
Discussion in 'Heavy Haul Trucking Forum' started by tomkatrose, Feb 7, 2014.
  1. tomkatrose
    tomkatrose Light Load Member
    224
    161
    Oct 22, 2010
    Los Angeles, CA
    Dumb question but I figure this group would know... can an 18 speed be shifted with just low range when the load is light?
    I'm thinking of switching from a 10 to 18 speed tranny for occasional off-road use or occasional RGN hauling. I don't have experience with an 18 speed and it seems intuitive that it could be shifted 1 through 8 without hitting the OD's but I don't know. Will it be hard on the tranny if I don't go through the OD gears?
    Thanks for the feedback.
  3. Pinner
    Pinner Medium Load Member
    410
    201
    Feb 14, 2010
    B.C.
    I never split the bottom box even @ 140,000, won't hurt a thing, same as a 13.
    M/T or loaded I always split the high range gears, just habit.
  4. Powder Joints
    7,663
    7,744
    Sep 25, 2007
    Rosamond, SoCal
    You can skip gears of the situation warrants it. If your rolling you just have to judge it about like a 13.
  5. rockyroad74
    rockyroad74 Heavy Load Member
    The only time I need to split low range gears is starting up a steep hill or off road.
    Normally loaded: I start in the low hole with the splitter back. Go L, 1, 2, 3, 4, range selector up, then 5, 6, split to 6High, 7Low, 7H, 8L, 8H.
    When empty: 1L, 2L, 3L, 4L, 5L, 6L, 7L, 8L, 8H.
    The beauty of the 13 and 18 is you can keep the RPMs between 1200-1400 most of the time. So you keep a steadier average speed, put less strain on the engine and driveline, and save fuel.
    Just don't abuse it, because it can break easier than a 10 speed if you do.
  6. Prom Night Dumpster Baby
    Prom Night Dumpster Baby Medium Load Member
    646
    473
    Jan 12, 2012
    Bug Tussle, TN
    When I'm MT my 10 turns into a 6 speed.
    4-6-7-8-9-10
  7. chicknwing
    chicknwing Medium Load Member
    526
    601
    Jan 4, 2014
    Charlotte, NC
    When loaded heavy my 10 is a 7 speed...2,4,6,7,8,9,10
    Loaded light 3,5,7,8,9,10
    Just never on a hill...
  8. tsavory
    tsavory Road Train Member
    1,910
    1,860
    Jun 4, 2013
    Paoli, IN
    3,5,7,8,9,10 90% of the time only seen 1 once last year real steep start at 79900 2 only crawling in traffic 4,6 crawling in traffic or long steep on ramps.
    I hate this super 10 1500+ at highway speeds and have to wait till below 55 to downshift on hills.
  9. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    If you dont ever want to move the little grey switch, it wont make a difference to the tranny.
  10. bigstick
    bigstick Bobtail Member
    25
    9
    Mar 12, 2012
    springdale, ar, 72762
    a super 10 requires a touch on listening to the engine, tac and road speed, that comes with 10 yrs of feeling the beast! Once you master the personality of the beast, it will put hard, run easy, and allow you to stay in the sweet spot for max fuel mileage. But if you abuse the beast, it will eat you up and destroy your wallet and you dreams of financial freedom are longer in realizing. You can make a 13 or 18 do the job, yet they are more forgiving than a super 10. A super 10 beast is non forgiving until you master the touch, than you are a true pro.....however it takes touch....
  11. abenaki
    abenaki Bobtail Member
    29
    4
    Jan 22, 2014
    It is fine to not split the low range. If you listen to engine, and it starts to "LUG", then it should be split. The engine will tell you if it is the right gear. When I'm empty, most often I even start out in 4th gear.
