Skipping gears from 8th 35MPH to 6th gear
Discussion in 'Questions From New Drivers' started by omar1999, Aug 6, 2025.
  1. omar1999
    omar1999 Bobtail Member
    26
    13
    Jul 20, 2025
    Hello everyone!
    I have a question if I’m driving 35 miles per hour in 8th gear, can I brake down to 25 mph, rev match around 1500–2000 RPM, and then shift directly into 6th gear and t's a 10-speed manual truck. How does that work? Thank you all for your help!
  3. Kyle G.
    Kyle G. Road Train Member
    3,888
    20,465
    Jan 23, 2016
    Eastern Iowa
    Just drive the truck!
  4. D.Tibbitt
    151,363
    Could you do it. Yes. But why? Theres no reason to do that. I mean you could brake from 8th gear all the way to 5mph and rev match into first if you wanted to... But why? Just downshift.
    omar1999 and Kyle G. Thank this.
  5. Grumppy
    3,115
    10,752
    Dec 11, 2010
    West Monroe, La
    Yes you can downshift and skip gears. To and from what gear, will depend on how the truck is geared over all. Its not all about the transmission. How the rear-end is geared, depends on the motor etc.
    But yes you can skip gears when down shifting. Just gotta have everything timed.
    gentleroger and Bean Jr. Thank this.
  6. tscottme
    tscottme Road Train Member
    Try it an see what your RPMs are like. Are the RPMs still in the normal range for going down the road?
  7. RockinChair
    RockinChair Road Train Member
    5,141
    13,021
    Feb 19, 2012
    CC, TX
    If your RPMs are really low in 8th gear at 35 mph then you might could skip a gear when downshifting, but make sure you don't have to exceed the engine's governed speed in order to do so.
    omar1999 Thanks this.
  8. TexasRiverRat
    TexasRiverRat Light Load Member
    287
    1,892
    Sep 4, 2021
    Why wouldn't you just go into 7'th?
    omar1999 and tscottme Thank this.
  9. tscottme
    When you are new it's probably better to drop/advance a gear out of a time until you mentally know the road speed, gear, RPM like you know your phone number. Frankly, I rarely knew the number of the gear I was using at every moment.
    D.Tibbitt, Numb and omar1999 Thank this.
  10. omar1999
    26
    13
    Jul 20, 2025
    The examiner told me I can skip gears, just in case if I didn’t have enough time to slow down to make a turn
    D.Tibbitt Thanks this.
  11. omar1999
    26
    13
    Jul 20, 2025
    Just in case if I want to make a turn and don’t have time to downshift every gear
