Skipping Gears when leaving the high way into the ramp and wide turns
Discussion in 'Questions From New Drivers' started by omar1999, Jul 20, 2025.
  1. omar1999
    omar1999 Bobtail Member
    29
    13
    Jul 20, 2025
    Hello everyone!
    I hope everyone doing well!
    I have my manual road test next week and I have a few quick questions. Can I downshift from 9th to 7th while exiting the highway into a curve if I brake from 45 to 25 mph? Also, what gear should I be in for a ramp curve at 15–25 mph? And when driving through curves, should I stay in the widest part of the lane—for example, stay left on a right curve that looks like a C and stay right on a left curve?
    I would appreciate your help guys!
    thank you so much for your time!
    austinmike Thanks this.
  3. RockinChair
    RockinChair Road Train Member
    5,227
    13,485
    Feb 19, 2012
    Lubbock, TX & thereabouts
    If this road test is for the DMV (as opposed to a pre-hire road test for a potential employer) then ask the examiner in advance if you're allowed to skip gears. That seems like a lot of braking in a pretty short distance, I might start slowing down sooner and be at the top of 8th (instead of in 9th) going into the ramp.
    6th.
    Try to keep all of your tires between the white and yellow lines. If that's not possible then do what you have to in order to keep the equipment away from the edge of the pavement, you don't want to make contact with the wall or drop a tire off into the grass.
    Good luck on your test!
    omar1999, A Bug, D.Tibbitt and 7 others Thank this.
  4. TripleSix
    132,252
    Be cautious about coasting in neutral. They can fail you for that.
    omar1999, OLDSKOOLERnWV, A Bug and 9 others Thank this.
  5. austinmike
    124,426
    I would not skip gears. They want you to drive exactly like you are supposed to. When I took my test in 2012 they wanted to see a death grip on the shifter.
    omar1999, A Bug, D.Tibbitt and 3 others Thank this.
  6. 201
    201 Road Train Member
    12,621
    25,905
    Apr 16, 2014
    high plains colorado
    Sounds like a job for the "mystery gear",,:D
    omar1999 and D.Tibbitt Thank this.
  7. broke down plumber
    3,956
    31,085
    Jan 25, 2024
    if its a automated manual do i still need a kung ## grip on my joy stick i mean shifter ?
  8. D.Tibbitt
    152,842
    No reason to skip gears. Learn how to downshift properly it may save your life one day... Also when u downshift, use the jakes to slow you down and drive like you have no service brakes at all. Just that technique alone will keep your truck out of trouble the majority of the time
    On ramp exits you will want to be 5-10mph less than the posted speed advisory for the curve until you get comfortable. Alot of new drivers have their first accidents at a clover leaf or ramp exit where the speed says 25mph and they roll in doing 40 or more
    The best advice to your other questions is drive the trailer not the truck. The truck will go where u tell it to, the trailer is just along for the ride.
    MACK E-6, tarmadilo, omar1999 and 5 others Thank this.
  9. austinmike
    124,426
    Leave your joy stick out of it. :eek:
  10. AModelCat
    161,299
    I never gave a rat's ### about what gear to be in for a given speed. I drove by the tach.
    tarmadilo, omar1999, D.Tibbitt and 2 others Thank this.
  11. 201
    12,621
    25,905
    Apr 16, 2014
    If you had one, that is. I drove trucks with a speedograph and a warning light. I just kept it to the floor, and let the gubnor do the rest.
    MACK E-6 and austinmike Thank this.
