Sleep apnea test question
Discussion in 'Questions From New Drivers' started by Jpatt, Jan 16, 2013.
  1. Jpatt
    Jpatt Bobtail Member
    So I've heard when going to a school for training they force you to take one of these test based on the that if I had to take your bmi. I know for a fact that my bmi would be high enough where I would have to take this antest and even though I don't think I have sleep apnea, I know how strict these doctors can be. So my question is, if you do have to have the test and need a macho ine, do they send you home or what? I've heard sovme people say they purchase the machine and take it out of your check. Any information would be appreciated, thanks.
  3. ralph
    ralph Road Train Member
    1,112
    632
    Mar 1, 2009
    At The Key Board
    I am sure every carrier has a different policy regarding sleep apnea, sleep testing and cpap machines.
  4. urgefan77
    urgefan77 Light Load Member
    55
    16
    Aug 29, 2012
    Not sure about schools, but Prime Inc will make you do a sleep study
  5. Bayle
    Bayle Road Train Member
    3,060
    1,228
    Aug 30, 2007
    Cottage Grove, MN
    Roehl, makes you take the test if your body mass index and neck size are too 'high'. They pay for the tests and if you need a machine will then take it out of your paycheck.
  6. interdude
    interdude Light Load Member
    171
    74
    Mar 28, 2012
    only way to rule it out is with testing,
    best for all who may be required (or even if just not sure) to get it done,
    it is very serious business that no one wants to mess with,
    a sleep deprived driver might as well be impaired
  7. interdude
    171
    74
    Mar 28, 2012
    what's the (why?) connection?
  8. ralph
    1,112
    632
    Mar 1, 2009
    At The Key Board
    Obesity is the biggest reason some suffer from sleep apnea....according to the experts
  9. technoroom
    technoroom Heavy Load Member
    830
    459
    Nov 8, 2012
    Personally, I think Roehl is just ahead of the curve here. When I took my DOT physical, the doc said he expected the BMI / neck size trigger to become fairly standard in the coming years, just as part of getting your medical card.
  10. jlkklj777
    jlkklj777 20 Year Truckload Veteran
    1,871
    1,090
    Oct 1, 2007
    Duncannon, Pa
    While there is no current regulation prompting doctors to demand a sleep apnea test for overweight drivers it is becoming pretty routine, especially within the Concentra network. God forbid you actually tell the doctor you snore or wake up during the night. This information will practically insure the doctor will demand a sleep study regardless of your size or weight. Of course companies are free to set their own standards when considering new applicants.
    Once diagnosed with sleep apnea you may have to wait as long as 3 months to get your DOT physical certified. The doctor at the DOT clinic will require documentation of compliance from the Neurologist or sleep clinic that diagnosed the patient with sleep apnea.
    Many drivers have difficulty adapting to wearing a face mask that constantly blows air into their nose/mouth. It takes time to get the correct air pressure setting for new cpap users. I know when I first wore a cpap mask the pressure was set too high. The best way I can describe the feeling is to stick your head out of a car window at around 60 mph and try to breathe normally. The rushing air makes it nearly impossible to get a normal breath.
    After multiple adjustments to the pressure setting I was able to get used to wearing the mask. Now I routinely sleep for 6 to 8 hours per night, feel better rested during the day, and do not require a nap in the afternoon. Other issues that improved while using the cpap machine were my blood pressure went down, my energy level went up, and recurrent heartburn stopped completely.
  11. KMac
    KMac Road Train Member
    3,427
    3,067
    Jan 26, 2012
    Waxahachie, TX
    It also has to do with the anatomy of your throat... something about the shape of it, also HBP is a factor.
    Stevens will make you take the test and if a machine is needed, they will finance it weekly and their trucks are equipet with apu's and power inverters.
